Old 05-25-2014, 04:59 PM
radio nut's Avatar
Born in the wrong decade
rca projection set
A friend is helping me with my rca 9 pc 41 -1949 projection set. He is cleaning up the rust and painting the chassis's while I do the rest.
Well today we got to looking at the concave mirror.....zero tarnish...shiny as all get out... and the coating silver is missing on a lot of it!
Does any one have a source for resilvering? there is no one in Lima, Ohio or any reasonably close larger city that I can find to re silver it.
Old 05-25-2014, 08:42 PM
Look for an astronomy club - you may find someone who does telescope mirrors and can help on this.
Old 05-26-2014, 07:13 PM
Tom Albrecht's Avatar
Look up Spectrum Coatings. I forget where they are located, but they did a nice job on the spherical mirror for my Philco 48-2500 projection set.
Old 05-26-2014, 08:00 PM
Polaraligned's Avatar
Polaraligned Polaraligned is offline
Nova Optics has done coatings for me in the past and has done a quality job.
http://www.nova-optical.com/Coating.htm
Old 05-26-2014, 08:10 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
If it's cost prohibitive, make a deal with this seller and I can part it out for you or hold it till you can get it http://buffalo.craigslist.org/atq/4455015139.html
Might be a treasure trove of parts, and the chasses look really clean.
Old 05-27-2014, 09:05 AM
John Folsom's Avatar
I have had several mirrors done by Spectrum Coatings with good results.
Spectrum Coatings:
Address:
1165 Ring St. Deltona, FL 32725
Phone: (386) 626-9782
Contact Person: Paul Zacharias
[email protected]
John Folsom
Old 05-27-2014, 11:11 AM
marty59's Avatar
marty59 marty59 is offline
I'd check with a nearby glass shop as most of them cut glass as well as make mirrors for specific sizes. Although you are in Lima, Dayton is a major area and there should be a few shops around.
Old 05-27-2014, 05:02 PM
Keep in mind these are special front surface mirrors where the reflective coating is on top of the glass. Not something your typical glass shop would have.
Old 05-28-2014, 10:35 AM
pearsonk pearsonk is offline
I have used H.L. CLAUSING in Skokie, IL for several mirror in the past.
I will use others in the future.
Old 05-29-2014, 10:41 AM
radio nut's Avatar
My mirror is not tarnished...at all. just losing small sections of the coating.
I got a hold of a resilvering shop and the gentleman stated that silver uncoated tarnishes very fast and maybe it is not silver ...but something else.
can someone with one of these sets chime in on it?
Is it actually silver and maybe some protective coating was applied?
So when I get time I will send him pictures of the mirror and get a ball park idea of the cost to re coat it.
Old 05-29-2014, 10:56 AM
While it is called resilvering, it is actually aluminum, which is evaporated onto the surface of the mirror by heating an aluminum pellet in a vacuum chamber, much the way CRTs are aluminized.
I have also used Clausing some years ago, but found Spectrum Coating to be less expensive.
John Folsom
