Old 07-02-2014, 02:04 PM
drdave3 drdave3 is offline
B&k crt 350,400
I have both of these testers. I can't find a manual for either, though I understand they use the same circuit, except for the meter.
Does anyone have a manual for these?
Thanks in advance!
Old 07-02-2014, 03:46 PM
Here's the manual: http://www.videokarma.org/attachment...0&d=1339696004
Here's the schematic: https://flic.kr/p/nUcJLg
Notice there's no setup chart because these are hard wired to only test 12 pin, 6.3 volt B&W CRTs. 10BP4, 12LP4, 16KP4, etc...
Old 07-02-2014, 08:59 PM
Bob, you're the greatest. Thank you very much! Is there any value in these? I just bought another one on eBay.
Old 07-02-2014, 09:56 PM
I hate to say it, but most of the value is probably in the three big neon bulbs.
Old 07-03-2014, 08:57 AM
It's a fine tester for B/W CRT's. You have to careful with the rejuvenation process. It's a little brutal. Dynamic intensifier, Medium should be used and that's when the CRT doesn't have any reading at all.
BTW, B&K made a color adaptor, that was a box with an RGB switch on it and a socket for a 21FJ type CRT. It connected to the 12 pin socket.
