Old 07-07-2014, 07:58 PM
dtvmcdonald's Avatar
Inductor characterization
While thinking of the "white crud" coil problems of CT-100s, I
thought of "how do you adequately characterize an inductor?"
so one that matches that characterization "just works".
It would seem that you need four numbers:
1) Inductance at low frequency
2) DC resistance
3) parallel resonant frequency
4) Q at parallel resonant frequency
I was also thinking that for air core coils #4 might
be superfluous. Clearly for magnetic core ones it, or something like it,
such as Q if resonated at the expected operating frequency,
is necessary. It would also be necessary for shielded coils.
Does anybody KNOW the answer to whether this is good enough?
Doug McDonald
Old 07-08-2014, 10:43 AM
bob91343 bob91343 is offline
How about inductance vs. direct current? Q at low frequency? And Q at resonance has little meaning, since by definition there is no reactance there, and Q is defined at reactance divided by resistance.
Old 07-08-2014, 10:56 AM
Ah, you are right about inductance versus DC in non-air-core coils.
You're wrong about Q at resonance, since resonance is a two-part thing:
Inductance with effective resistance in parallel with essentially
perfect capacitance. The Q is that of the inductor alone.
