Old 08-12-2014, 03:24 PM
rlovison rlovison is offline
More lightning damage
I have a Sony Bravia LCD KDL-46BX420 that was also a victim of a lightning strike. When I plug this set in, I get two distinct clicks and then nothing. The voltages are in the tenths of volts or 0 at the output leading to the main board. If I unplug and plug in again I won't get any clicks from the relay unless I wait a few minutes before plugging in. All the diodes check out ok on the power supply board, fuse is ok along with the resistors (none were open). Not sure where to start with this one. Does anyone have any pointers on where to begin? Thanks.
