Old 08-22-2014, 08:12 AM
Gregb Gregb is offline
Dumont RA103
I picked up a really nice condition RA103 and on checking the CRT the filament is open. Tried resoldering the lead wires with no luck. From what I have read it would seem the original CRT is a little hard to find so what have you fellow RA103 owners used for a replacement and what changes if any were needed?
Also if anyone has a spare they are willing to part please let me know.
Thanks
Gregb
Old 08-22-2014, 10:54 AM
a 12LP4 will work but the neck is a little longer and would touch the back and you would have to change the anode end , i'm sure there are other 12" crts that would fit but the numbers aren't coming to mind, i hae a 12QP4 laying arround but it is so weak that my friends beltron really couldn't help it.
Old 08-22-2014, 10:55 AM
baursam's Avatar
baursam baursam is offline
try El Predicta on here, he has a lot of tubes and I would be surprised if he didnt have one. I am pretty sure that is where I got mine.
Old 08-22-2014, 12:47 PM
Thanks guys, I will look into both suggestions. I am really looking forward to getting this one working. It is the earliest set I have and it looks really cool!
Gregb
Old 08-22-2014, 08:15 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Doesnt stellartv have some too???
SR
Old 08-22-2014, 09:07 PM
Tubejunke's Avatar
What is the correct c.r.t. so anyone who may have one will know?
Old 08-22-2014, 09:36 PM
tvdude1 tvdude1 is offline
They use a 12jp4
Old 08-22-2014, 10:53 PM
Yes, sorry, 12QP4 or 12JP4 is what shows in my Dumont manual.
Gregb
Old 08-23-2014, 01:51 AM
baursam's Avatar
I have the aluminized version 12KP4 in mine, right length, brighter picture, no ion trap. 12LP4 is slightly longer, and works fine, but back must be removed. Stellar TV does have 12LP4 s I believe. 12JP4 is very hard to find, at least when I was looking.
Old 08-23-2014, 05:57 AM
Find a 12kp4 its shorter .
Old 08-23-2014, 08:37 AM
OK, 12KP4 seems to be the way to go. Anyone have one they can part with?
Thanks
Gregb
Old 08-24-2014, 01:09 PM
Tim's Avatar
Tim Tim is offline
This Sylvania chart posted on the ETF site lists several other subs and the differences from the original. 12RP4 is a close sub but they are rare. The chart even shows larger size tubes that are electrically compatible for use when increasing CRT size.
http://www.earlytelevision.org/pdf/c...nce_manual.pdf
Tim
