Old 10-10-2014, 01:47 PM
knockbill knockbill is offline
Sanyo Chassis #G5Y-3258GO
This set just developed a horizontal white line across teh screen,,,happened this morning, and again just now,,, Searching finds to to most likely be a loose connection, damaged trace or bad cap in teh vertical section...
I hang out in teh audio tube forum, and found this one for TVs...
Is there any place to down load a schematic for this set? I may be able to track down the problem, if I knew where to look...
Right now it has a good, clear picture, but, I believe it won't last...
Any help is appreciated..
Regards,
