Old 10-16-2014, 04:33 PM
pac.attack76's Avatar
Stuck in the past
1998 Sony KP-53s65 53" Projection Problem
Set runs normal except for some color offset in some areas. Almost like convergeance but not consistant. Uneven in some areas and even mostly in the bottom right corner. Got the idea to block off the blue lens and that corrected it. What could be causing the blue to be offset? Everything else is good. Tried marking and rotating the adjustments on the neck but nothing happens. I did notice slight movement when i passed the magnectic tip of my screwdriver next to it.
Old 10-16-2014, 10:17 PM
rca2000's Avatar
rca2000 rca2000 is offline
Not sure what you mean by "offset" could be convergence and INTERMITTENT convergence problems are VERY common. A set of this age almost DEFINITELY needs convergence IC's assuming it uses them. A few--VERY few Sony sets had discrete amps for convergence...but not many.
But also could be bleeding. Sony sets are NOT known for the best tubes--unlike RCA sets from the same period--which have tubes that seem to last forever..try turning up the blue screen...see if that might make a difference.
Old 10-17-2014, 04:32 PM
While it does not list your specific model, I think this service bulletin from Sony is germane to your model. Bad solder joints cause problems, and could lead to convergence IC failure, as RCA2000 mentioned.
USN RET 22YRS (Avionics/Cal)
Old 10-17-2014, 06:11 PM
Stuck in the past
Yeah, the red and green is perfect. turned up the blue and didn't change. by offset, i meant that it is inconsistantly curvy across the top and pulled downward the left side. pretty good down toward the bottom right. i figured if it were convergeance, then th whole thing would be evenly offset across the entire screen. So i'll need to replace these ics?
Old 10-17-2014, 07:06 PM
rca2000's Avatar
This REALLY sounds like a convergence problem !! Mis-shaped raster on a projo on ONE color--is most always a convergence problem. And NO ...convergence problems do NOT often cause an "even offset" _-often it is wavy and weird-looking.
Old 10-20-2014, 04:04 PM
Stuck in the past
Probably is. What i was referring to was that using the crosshair in the menu won't work. You can see how wavy it is in the pics. Do i need to replace ics?
Old 10-20-2014, 04:55 PM
rcaman's Avatar
rcaman rcaman is offline
yes you do and use original sanyo ic's not china generics. trust me on this one. good luck steve
Old 10-21-2014, 06:59 AM
The conv board from your other set may be the same.
If not the IC probably are. If you swap boards be sure
to resolder all the IC's.
Another thing that can go is the voltage that run the IC's.
IIRC they use apx -15 & +15 volts. If an IC shorts it
will either open a resistor or a little choke coil. More on that
if needed...............
Old 10-22-2014, 03:56 PM
Stuck in the past
Where would they be located?
Old 10-22-2014, 05:21 PM
Probably near the flyback, possably on the conv board.
Sony marks things well so look on the conv board for the voltages.
Start at the harmonica connectors. There may be other voltages coming
in like 5V, 9V, 12V to run the rest of the board.
If it has resistors they will be abt 1 ohm 1 watt. The coils
may look like small white rectangles with wax on the top, at
least on the older ones they did.
Old 10-23-2014, 03:48 PM
Stuck in the past
What letter would be on the board cause they are all labeled.
Old 10-23-2014, 05:25 PM
I was thinking of measuring the voltages IF the IC's dont
fix it.
Old 10-24-2014, 03:58 PM
Stuck in the past
fix it.
Right. im not familiar with convergence so I'm wondering what letter it would be. Main power board is "A" and video section is "G". Those are the two biggest boards in there. Then there are CG, CR, etc. I don't even know where the thing is.
Old 10-24-2014, 05:49 PM
OK I get it. Dont remember what the letters were. It will
have 3 big IC's all the same on heat sinks. Maybe someone
has a manual ?
Old 10-25-2014, 05:50 PM
Stuck in the past
has a manual ?
No problem. I found the two largest ics in there labeled something like STK 392 150 near the power supply but those should be audio. I'll poke around google.
Update: I guess it is the STKs. There's two and they're big. Problem is, the spares i have from the 48" are stk 392 110. Will 110 replace the 150 or no?
