Old 11-20-2014, 10:10 PM
Doug66 Doug66 is offline
Silvertone 8106
I picked this up off my regional Craigslist last week and thought I could do a quick restoration on it. However, when I took the back off tonight, I was greeted by the following: see pics. It looks like the yoke cover melted. This is as far as I've gotten.
Old 11-20-2014, 10:53 PM
As awful as that looks, it's possible the yoke may still be sound. Some covers were made of a miraculously cheesy plastic that self-destructs. I haven't seen one quite that bad before, but I have seen covers that were warped all to heck, with pieces falling off, etc.
I would withhold judgment for the time being. If the yoke turns out to be OK and you finish the remainder of the project, you can fashion a substitute cover later on.
Phil's Old Radios
Old 11-21-2014, 02:56 PM
Is that a Philco style circuit module (top center of the picture)?
Maybe Philco made this set for Sears...
Old 11-21-2014, 03:26 PM
robert1's Avatar
robert1 robert1 is offline
This was a common ocurrence with these yokes from the 50's & 60's. the material used to make this plastic like cover would deteriorate because of heat. the deflection yoke should be Ok. the problem with these plastic covers is that they also hold the centering rings in place. when the plastic cover deteriorates, you will not have any way to center the picture.
Old 11-21-2014, 03:28 PM
Couplates are not specific to Philco. RCA, GE, Motorola, and others used them as well. This set looks like either a Warwick or Westinghouse to me.
USN RET 22YRS (Avionics/Cal)
Old 11-21-2014, 03:42 PM
robert1's Avatar
Warwick Electronics of Chicago built this set.
Also, It Is not a "Philco" style circuit module, it is referred to as a "Encapsulated Circuit Module". there were two manufacturers that made these "E.C.M's" Centralab & Erie. the red modules were built by Centralab. these were used by many electronics manufacturers during the late fifties all the way up to the early seventies.
Both Centralab & Erie Would build these to manufacturers specifications. these were mainly resistor / capacitor circuits.
Old 11-21-2014, 05:01 PM
I've gotten the chassis out of the cabinet and cleaned up the mess. I'm wondering if one of the electrolytics shorted causing it to overheat. The 1st one pictured looks to be oozing its insides. It's a 5 section unit. haven't seen one that big before.
The 2nd electrolytic is one that I've never encountered before. It has a positive and negative at both ends. Normally, dual or multiple units share the ground.
Yes, this set does have couplates. I took a pic of the largest one, 15 components. I've watched bandersens Predicta restorations, and I've used his techniques to rebuild the couplates in a Philco Briefcase I recently restored. I'm also currently restoring a Predicta and will be rebuilding the couplates in it within a week or so. However, I hope I don't have to do that in this set. It has a 15unit, a 13 unit, and an 11 piece unit.
Old 11-21-2014, 08:01 PM
It's actually two separate, unconnected caps. One is the doubler input cap, IIRC.
The first time I ever replace one of those, I (mistakenly) thought the red lead coming out one end went with the black lead coming out the other end, and proceeded to wire it accordingly. The dang set came on and worked, but with humungous hum bars and hourglassing.
I quickly corrected the goof.
Old 11-25-2014, 06:54 PM
I finished replacing all the electroltyics today aw well as the two rectifiers. I tried a power up with my Variac. Not very good results. Tubes lit but no sound no raster. Unfortunately this set is one of those where the chassis is a square with a cutout in the center for the CRT which stays in the cabinet as the yoke can be unplugged. To make test on the underside, I'll have to pull the yoke off the CRT and use my test CRT.
Old 11-25-2014, 11:23 PM
This is where having a test jig with a 'universal' yoke becomes rather convenient.
Old 11-26-2014, 12:36 AM
Well, after my last posting, I pulled the yoke off and hooked up to my 5" test CRT. I was rewarded with a raster but still no sound. Either something is amiss with the correct CRT in the cabinet or I turned up the wrong control for brightness when I made my initial power up. The controls aren't labeled, and I don't have a Sams for this set. Hooking up a signal gave me a pic, but I couldn't get the vertical to sync. Right now I'm recapping the sync board.
I'd like to know who built this set for Silvertone. I've already had one PC trace lift up on the sync board despite how careful I was. Even though the Predicta I'm also working on was a pain to recap, I didn't have 1 trace lift up during it's recap.
Old 11-26-2014, 01:09 PM
robert1's Avatar
Warwick Electronics of Chicago built this set for sears.
i stated this in a earlier post.
Old 12-05-2014, 08:04 PM
I've got all of the capacitors replaced. That allowed me to lock in the vertical temporarily. The audio output transformer was open, so I replaced that. Now I have bad sync in both horizontal and vertical. I've subbed new sync tubes and replace the resistors in the sync circuit. It starts as a wavy pulling at the bottom of the screen hen travels up to the top. I cannot get that straightened out with the horiz hold. The vertical also loses sync too. This set is so simple, I can't figure out what I have overlooked.
Old 12-05-2014, 08:57 PM
dtvmcdonald's Avatar
With that symptom one always worries about a bad AGC resulting
in very compressed sync pulses. Scope the video.
Old 12-05-2014, 10:23 PM
Are you still using all of the original couplates? What circuits are they used in?
What's your video source? (Weak signal can cause weak sync and result in bad horizontal & vertical lock).
Phil's Old Radios
