Old 12-31-2014, 11:57 AM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
Sony KV-9200
Hello all,
This is a set I picked up this summer, but did not got around to mess with until this morning. It is a Sony KV-9200, there is no date on the back cover but I think it was made around 1972/73.
After a grayscale ajustement (picture was too green of course) it came out great. But I find that it is not as sharp as it should be , so I went to ajust the focus pot and... I looked around and couldn't find it haha.
This set seems to have a lot of little problems : picture is tilted (probably need to reposition the yoke), colors seems to pop from too green to ok randomly(maybe dirty pots?), its got a little pull in on both side, there seems to be a problem of cross talk in the upper portion of the picture that fades away after the sets has been on for awhile (just like my 1979 Hitachi) and the picture is of center.
So all in all , not a bad set at all, but needs a little love.
What do you guys think of it?
Happy new year!!
Old 12-31-2014, 01:18 PM
if it has a pincusion adj pot, and if it does not work, then prob a dried up cap (at least that is what it was on a couple KV-1212's I recently worked on).
Old 12-31-2014, 01:37 PM
Pincusion would be for the pull in right?
Old 12-31-2014, 04:00 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
That's right. And for what it's worth, the focus pot on the only Sony I've been into was on the neck board. There was an access hole, but I didn't have a tool small enough to adjust it so I had to do so from behind.
Old 12-31-2014, 04:07 PM
pincushion is typically on both sides (side pin cushion) as seen on the photos you attached. The Sonys I worked on only had side pin cushion adjustment.
Focus was done with a selection of voltages, you had to move a jumper around. I am no sony expert, just telling you what I came across on those KV-1212's
Old 12-31-2014, 05:20 PM
The service manual for my (earlier) KV 9000 shows a pincushion adjustment (VR910) only on some sets (chassis SCC-B01-EA S/N 29001 and later). I do not have it on my set. My pincushion distortion is moderate, so perhaps the adjustment is lacking on your set as well.
My KV9000 in this post:
http://www.videokarma.org/showpost.p...6&postcount=15
edit add: On my KV9000, the Focus is adjusted by connecting the yellow wire to one of the four positions (0,250,550,660 volts) on the "P" board, which is visible with the back off, above the power plug. Since your 9200 layout looks different it may or may not have a similar focus "adjustment".
OBTW, I really like the smoother appearance of your 9200, might try to add one to my small collection of "mini-trons".
Old 01-01-2015, 07:36 AM
Marco-nix's Avatar
Mine is a KV-1204 and I need a schematic..any help will be appreciated..I have the same problem....
Old 01-01-2015, 08:26 AM
I am looking for conventional well labeled pot, or something more subtile with only a component number like VR910?
As for the focus , I definitly didn't seen any pot around the set (even on the neck board) for that ajustement, It might very well be the jumper style selector. But given the fact that this set is very cramped, its hard to make anything out.
Edit for jr_tech : and I like your more angular kv-9000 look too :P
Old 01-01-2015, 08:31 AM
What problems exacly? People may be able to help if you describe specific problems.
Old 01-01-2015, 10:50 AM
My KV1204 manual is missing. I have the KV1204A manual,
things may be the same OR very different.
The pin control is VR541 The cap that goes is C541 10mfd. Its
off one end of the control. Its all tward the rear of the right
hand board ( looking from behind) . The board is on
hinges so you can fold it back.
Old 01-01-2015, 11:06 AM
Pin problems give an hour glass shape. Adjust it to far & it
takes a barrel shape.
Pin control is VR504. The cap that goes is C521 its off one end
of the control. The manual says its either a 1mfd or 3.3mfd.
There may also be a 1mfd tacked in in parralell with it
prob under it. Use whatever it used.
Focus is a tap marked F1, F2, F3. probable wont see any difference.
Color problem check for bad solder on CRT board & dirty
controls. Common conections are at socket itself & the 3 output
transistors. That will keep you busy for now.
Old 01-01-2015, 11:54 AM
I'll get right down to it! Thanks!
Old 01-02-2015, 07:37 AM
Marco-nix's Avatar
If you want to send me a pdf of your schematic, i take it Zeno. your is probable the same that my own Sony....just communicate in private
Old 01-02-2015, 07:41 AM
Marco-nix's Avatar
Wink
I have the same problems as your television. Finally, almost all ... according to what I see on the pictures you put in your message, mine has the same problems.
Old 01-02-2015, 09:09 AM
Right! In that case stay tuned.
So I found the pin adjustment pot (you can get to it on the right side of the set as showed in the picture), and got rid of the hourglass shaped picture.
Also found the F1, F2 and F3 focus holes (see picture 2) , If I understand correcly the wire starts from F0 and goes to either F1, 2 or 3 right? So in order to try and adjust the focus I have to unsolder the wire from F1 and try F2 or F3?
As for the colour kicking in and out , I think its the CRT board because while adjusting the Pin cushion, I was gently tapping the board with my plastic tool and found that it accentuated the problem...so I will reflow the suspects connection.
