Thread Tools | Display Modes |
https://www.youtube.com/watch?x-yt-c...tailpage#t=344
SX-60 Quote:
Radio (s)hack sold AM stereo tuners....By the time AM stereo came out aside from perhaps hobby kits there was not market for AM stereo adapters since most consumers were tech illiterate by then.
Likely not available to you easily. If offered at all.
I know its not Pioneer.I found a Delco AM stereo/FM stereo cassette at the fleamarket years ago cheap.I modified it with line outputs before the volume control with coupling caps. I can direct feed my digital recorder with no overloaded signal.
I do enjoy those Super tuners they made. |
| Audiokarma |
HERE exampleAnd in JAPAN is wide use am stereo ![]() https://translate.google.co.jp/trans...Fst-gt550.html https://translate.google.co.jp/trans...27508;史 Last edited by svhs; 01-20-2019 at 06:14 AM. Reason: Logged in as svhs Reason |
There once was a CQUAM adapter for these and other brands of receivers on Ebay. I still have one.
Rick (Sparks) Ethridge |
am stereo ALERT
![]() ![]() https://www.worthpoint.com/worthoped...o-fm-136441406 Quote:
Sony ST JX520A
![]() ![]() ![]() It operates at 8-15VDC and provides standard level left and right audio output for direct connection to the audio amplifier. It may be used to support 30Hz-15KHz audio but it depends on the bandwidth of the receiver's IF. Read more: http://rf-circuit-schematic.blogspot...#ixzz5g2Skh9Xd ![]() http://meduci.com/Rich Modafferi built his "connect to any radio" AM stereo decoder enclosure to house his meduci AM_ST decoder board, which complements his tube-based AM stereo C-QuAM transmitter. Rich also used his Sencore SG80 stereo generator for testing purposes. His enclosure has inputs for 455 kHz I.F and a level control is provided for adjusting this I.F input. There are both BNC and RCA I.F input jacks, and fixed and variable audio level outputs. Single indicator lamp functions for "power" and "stereo", glowing dim on power, and full bright for AM C-QuAM stereo lock.
