Old 02-10-2015, 12:14 PM
sansui2000A sansui2000A is offline
Schematic for Magnavox 14MS2331/17
Does anyone have a schematic for this set? It seems to have a tuner problem plays DVDs from video inputs fine, but nothign from antenna input.
I hate to just trash it
Thanks
Old 02-10-2015, 12:38 PM
What chassis? L03.2?? I may have a manual, but need the chassis number. Tuner functions can be turned off in the service menu - was the set always like this, or did tuner functions quit?
Also, this model series has only the NTSC tuner, won't work without a digital converter or cable/satellite box. Check it with a channel 3/4 input source - it may work.
USN RET 22YRS (Avionics/Cal)
Old 02-16-2015, 05:36 PM
The set was working on cable but stopped one day it is my daxs tv so maybe the tiner functipn was disabled by accident. Ill check on the chassis number i hate to toss it hasnt bren used much
Old 02-17-2015, 06:21 AM
Marco-nix's Avatar
Probably not the timer fonction because there's a special procedure to do for finding a ( secret menu ) so your problem is surely the tuner....check the welds under the board where is the tuner..If you can put ON the tv, the problem is the tuner especially as you said it has been in operation
Old 02-17-2015, 02:46 PM
What cable system? Connected to a cable box, or direct? Some cable systems dropped analog channels, so this set would then have to be connected to a cable box. It may be functioning perfectly, just needs that analog signal source.
Old 02-17-2015, 03:09 PM
Marco-nix's Avatar
You're right findm-keepm.. This option can also be retained, I had not even thought
