Old 02-22-2015, 04:03 PM
Gregb Gregb is offline
Philco 50-701
I am working on my Philco 50-701 at the moment and overall it is working great but the retrace lines are a little annoying. Has anyone added retrace blanking to this model and would you be willing to share what you did?
Thanks
Gregb
Old 02-25-2015, 10:07 PM
Perhaps you can adapt the 19A1 Admiral retrace modification. That design has the video feed into the cathode while the grid controls brightness. http://antiqueradio.org/art/Admiral1...ingCircuit.jpg
The 50-701/2 uses the grid for video and cathode for brightness. That means you'll need a positive pulse on the cathode for blanking. Anyone try this ?
Old 02-25-2015, 10:20 PM
Thanks Bob, yes that is my question. I have used that circuit for my Admiral set and it works fine. Anyone know how I can modify this to work in my Philco? I have finished re-capping and a number of resistors and it works great other than the retrace lines are a little annoying. I can adjust them out but would be nice to get a little more brightness.
Gregb
Old 02-26-2015, 01:58 PM
You can always try a RC decade box, and try different polarities of vertical waveform different RC values, and different points in the video chain until you get it right....When a pre-designed solution is not available decade box engineering can work wonders.
