Old 03-26-2015, 08:03 PM
GaryK's Avatar
GaryK GaryK is offline
W9TOF
Location: Eastern Rural Walworth County Wisconsin near the southern Kettle Moraine Forest
GE Portacolor MFG Year Identification
Hello- I have a GE Portacolor set model WM212HWD-4 with an H-4 chassis.
The serial number is 5L30 19625.
Can any member give me the year of manufacture of this set?
Old 03-26-2015, 08:27 PM
tvcollector's Avatar
I bet that's the same one that was on eBay last week, that ended on Friday night.. I was going to bid... But than forgot, and on top of that, it went a bit higher than what I would have paid for it..
Old 03-26-2015, 08:55 PM
Sams shows a number 1223 folder, dated 3/72. The set's probably a 1971 model year.
Old 03-26-2015, 10:14 PM
WISCOJIM WISCOJIM is offline
Welcome, Gary. Good to have another Wisconsinite join us! There appear to be a lot of WI & IL collectors in this group.
If you haven't heard of WARCI, TVs have been known to show up at our swap meets. The next meet is this Sunday. See www.warci.org for more details.
Jim (Appleton, WI)
Old 03-27-2015, 12:35 AM
Olorin67 Olorin67 is offline
Date codes on the tubes will give you a good idea. Mine has 1967 date codes. My set looks identical to yours.
Old 03-27-2015, 09:21 AM
I think, that was the last year for the cabinet mounting screws in the front. I have a year newer model and the cabinet screws are in the rear.
That model, still has the low voltage focus CRT. 11WP22.
Old 03-27-2015, 02:32 PM
A-yep!
H-3 chassis (I have one with all the GE documentation/service lit) is 1970, so yes, the H-4 is 1971. The HE chassis PortaColor was introduced in 1972, 1973 introduced the 10JA chassis solid-state PortaColor, and 1974 was the 10QA Chassis PortaColor so your set is among the last of the all-tube models.
USN RET 22YRS (Avionics/Cal)
Old 03-27-2015, 03:35 PM
I have several porta colors, I always thought that layout was on later 60's era sets.
Old 03-27-2015, 05:36 PM
Originally Posted by Findm-Keepm View Post
A-yep!
IIRC, the H-4 is the first chassis to use a 12JF5 and a 1DG3 high voltage rectifier. It also had the safety capacitor on the PC board, near the horizontal output tube. The newer chassis, had the cap on a terminal strip on the side of the hv cage.
Slight differences in the power supply circuitry on the H-4 vs the earlier models.
Old 03-27-2015, 06:59 PM
Date codes on major parts is the best way. Also tubes
are coded but IIRC GE used a screwy code.
IIRC original tubes had blue lettering & replacement white ?
Old 03-27-2015, 07:15 PM
GaryK's Avatar
W9TOF
Actually no. I have had the set for many years. I acquired it around 1985 when I was working as a TV/VCR tech.
Old 03-27-2015, 07:17 PM
GaryK's Avatar
W9TOF
Jim (Appleton, WI)
Thanks for the welcome Jim!
Old 03-27-2015, 07:18 PM
GaryK's Avatar
W9TOF
I am thinking it might be from the mid or late 1960s.
Old 03-27-2015, 07:23 PM
GaryK's Avatar
W9TOF
I'm thinking 1965 or 1966.
Old 03-27-2015, 07:48 PM
GaryK's Avatar
W9TOF
A-yep!
OK it looks like 1971 is the answer and thanks!
