Old 04-24-2015, 12:49 AM
Titan1a Titan1a is offline
NOS 6U5 Tube fail?
My Zenith 7S363 has started developing problems since being electrically restored. I noticed the, formerly bright, 6U5 tube start to noticeably dim. I know these tubes are known to deteriorate but this is unusual to me. Anyone have ideas?
Rick (Sparks) Ethridge
Old 04-24-2015, 09:38 AM
Was the resistor replaced in eye tube socket? It generally affects the opening and closing of the eye, but stranger things happen. Also check the B+ voltage. The set might appear to perform properly, but the B+ could low.
I have the very same set. It needs a new grill cloth and the cabinet can use a little attention. The tuning eye is a little dark as well.
Old 04-24-2015, 11:37 AM
Discussion on brightening eye tubes here..
http://www.nostalgiaair.org/Forums/M...0/M0066090.htm
Old 04-24-2015, 07:01 PM
More discussion here:
http://radiomuseum.org/forum/lightin...eye_tubes.html
As the P-1 phosphor used in these early eye tubes is subject to Columb ageing, the trick is to increase the target voltage for increased brightness *while* reducing the target current to reduce the rate of ageing.
Old 04-25-2015, 01:37 PM
I appreciate the replies to my message. While I've purchased an additional tuning tube and also have a questionable spare I will take your advice seriously. New tubes are no longer manufactured and building a solid-state substitute would be difficult. I believe that a solution based on your advice is possible as does my friend/technician.
