Old 04-29-2015, 08:45 PM
Adam's Avatar
Adam Adam is offline
Admiral 17T12
I'll have a little more free time after next week, so I'm hoping to fix this set this summer (along with that partially rewired Philco 39-116 chassis sitting next to it in the pic). I've always liked the look of this Admiral.
I have the knobs, but not the back. The cabinet has 1 crack in the bottom I'm going to have to glue back together. And I don't really like that someone drilled a hole in the front to put an earphone jack, but I think I'm going to wind up just leaving it. I could fill the hole, but the only way it would look good is if I then painted the cabinet, which I don't really want to do.
It looks like they never made a sams for the 17T1 chassis. But I did find a schematic for it here: http://www.earlytelevision.org/pdf/a...1_telaides.pdf I also have the sams for the 19A1 chassis which looks very similar.
Old 04-29-2015, 09:56 PM
ZackN920's Avatar
ZackN920 ZackN920 is offline
Hey Adam, did you happen to buy this set recently on eBay, perhaps on Sunday? It looks exactly like the Admiral set I was bidding on that had no back and had a headphones jack drilled into the front. I lost it by about $15.... I was not happy, but if this is that set, im glad to see it went to a good home. Good luck with it bud.
Old 04-29-2015, 10:25 PM
Adam's Avatar
It's the same set, I had been looking for one of these 7" Admirals. Because I like the models with this grille better, I decided to go for it even though it had the hole drilled in the front.
Old 04-29-2015, 10:38 PM
ZackN920's Avatar
Ok, cool. Honestly I've just been looking for any decent 7" set. This one really looked nice to me and I'd read that their a good running set too, once restored. Welp, keep us up to date with your new project!
Old 05-01-2015, 08:41 PM
Adam's Avatar
I had sold all my round screen b/w table sets except for my 7" Airline, and thought I wanted another one. This model Admiral I've always thought had one of the better looking cabinets for early b/w's. Good luck looking for a 7" set. The Airline I have is also a pretty good performer, it uses a power transformer like the Admiral (I think the Airline has the same chassis used in the Sentinel).
Old 05-16-2015, 11:12 PM
Adam's Avatar
I thought I was going to get far enough with recapping this to try it out tonight, but I just noticed a broken 5Y3 socket. Now I probably won't get to firing it up till next weekend...
Old 05-17-2015, 11:11 PM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
I’ve seen a few people on this forum who have 17T1’s or 19T1’s without a back. A good reproduction can be made inexpensively with minimal tools and a lot of patience. I don’t know of anyone (other than me) who has actually made one, but if you’re interested, here’s a link to a “how to make it” discussion:
http://www.videokarma.org/showthread...ferrerid=70422
Winky Dink
Damn the patina,
Full speed ahead!
Old 05-19-2015, 06:48 PM
Adam's Avatar
That's a nice looking replacement back. I downloaded your template. (Although I'm not sure if I'll attempt to make a back this summer.) That material seemed like it was hard to work with, I wonder if it might be easier to make a metal one.
Old 06-15-2015, 05:58 PM
ZackN920's Avatar
Hey Adam, have ya got it going yet?
Old 06-17-2015, 08:38 AM
Adam's Avatar
I've got it basically working. The one minor problem left is: after it is on, working good, for several minutes (sometimes as much as a half an hour) I start seeing the occasional horizontal black line going across the bottom 1/4 of the picture. This is accompanied by jittery (but it doesn't loose sync) vertical. (I've already recapped, changed that 5Y3 socket, realigned the audio IF, added vertical retrace blanking, and replaced most of the resistors which have anything to do with vertical output in the process of fixing a previous problem it had of not enough vert size) But I'm not sure if this could be caused by a vertical problem anyway, the way it seems to turn single horiz lines on the screen dark. Any thoughts?
Old 06-20-2015, 06:11 PM
Adam's Avatar
I don't know exactly what it was, but I did a bunch of resoldering and cleaned all the controls, and it seems to be working ok now. One thing I think was definitely contributing to it was a resistor (attached to the vert lin control) that was just barely tacked onto the terminal strip it attached to. I almost always seem to find a few goofy repairs like that in sets this old. I also (back when I was recapping) found two resistors that were replaced with ones that were an order of 10 off in value. In comparison, I almost never find stuff like that in sets from the mid-50s or newer.
I still have to clean the cabinet, glue that crack on the bottom, and maybe I'll try to make one of those backs...
Old 06-21-2015, 01:05 PM
Adam's Avatar
I cleaned the cabinet...
Old 06-21-2015, 02:37 PM
Looks great I've cleaned some 19A11 cabinets and know how tedious it is
Old 06-22-2015, 12:50 PM
Adam's Avatar
This one was at least pretty clean on the outside to start with. I Still spent a good amount of time trying to polish up the top though. And the inside had some yucky old insect nest looking stuff packed in it.
Old 06-23-2015, 12:08 AM
ZackN920's Avatar
Ooh-Looking good... Are ya going to leave that modification in it?
