Old 05-13-2015, 12:54 AM
What do you use to get paint specs/flecks off a wood tv cabinet ?
Without redoing the finish , curious of the different methods that can be done.
mike
Old 05-13-2015, 03:42 AM
stusnyder's Avatar
mike
Goof off works pretty good.
Old 05-13-2015, 04:42 AM
decojoe67's Avatar
It may sound dangerous, but a brand new safety blade! You very lightly glide the blade over the finish, nearly flat, but just lifted slightly. The paint drops just pop-off. Sometimes you have to use a bit more pressure right near the paint drop. If there's a residual mark, it will be easily be removed with a cleaning product. I do this one any type of surface. I've used this technique for decades and it makes quick time of the job.
Old 05-13-2015, 05:43 AM
Polaraligned's Avatar
Polaraligned Polaraligned is offline
I have had best luck with my fingernails...
Old 05-13-2015, 07:09 AM
+1 here, and the Chicago Tribune agrees.
http://articles.chicagotribune.com/2...e-cherry-table
USN RET 22YRS (Avionics/Cal)
Old 05-13-2015, 09:38 AM
WISCOJIM WISCOJIM is offline
I use a credit card.
Old 05-13-2015, 11:40 AM
If it is latex paint, you can lay on a rag soaked with mineral spirits (paint thinner) and leave it for a while. The paint drop will soften and rub off (with a soft rag) pretty easily. Mineral spirits will not harm a lacquer finish.
Some of the answer depends on the underlying finish and the nature of the spot. If the underlying finish is tight and solid, and the paint drop has enough thickness, you can pop it off with a fingernail or credit card, etc. If the underlying finish is weathered and the paint drop is thin or it has smeared into miniscule cracks/crazing of the finish, soaking with paint thinner and rubbing may be needed.
Old 05-13-2015, 12:29 PM
Gregb Gregb is offline
I have a Philco pedestal with a bunch of paint drops on the plastic, I have tried the finger nail with no luck. Any thoughts on this?
Gregb
Old 05-13-2015, 07:02 PM
NoPegs's Avatar
NoPegs NoPegs is offline
The glass is -3dB.
Gregb
Granulated Sugar and fingertips.
Old 05-13-2015, 08:44 PM
Gregb
IIRC someone here mentioned oven cleaner.
Old 05-13-2015, 10:44 PM
I would think oven cleaner would damage the plastic.
Gregb
Old 05-14-2015, 12:32 AM
I mentioned the Oven cleaner after someone here had told it to me.
It worked great on a 1959 RCA that had it's bezel painted pink, should work on a Predicta, but as always, test on an inconspicuous area.
It took a while to work, I think it was Latex house paint, if it were Lacquer or Enamel it might etch into the plastic and never come off, in that case you would have to sand it off and re-polish the case.
Predicta plastic responds very well to polishing, I completely sanded and polished the CRT housing on my Pedestal to get rid of the scratches, also had to do the screen cover, those polish well also.
Old 05-14-2015, 08:27 AM
I certainly looks like it did a good job on your RCA, I may give it a try. Other than the paint drips my plastic is in excellent condition with very few scratches.
Gregb
Old 05-14-2015, 08:46 PM
Radiotronman's Avatar
I've had really good luck with Easy Off, oven cleaner believe it or not. Works great on getting those mold spots off knobs and cabinets, that usually reappears later. Just put a small amount on a rag, let it bubble a little, wipe it on and buff quickly. It'll take them right off.
Old 05-15-2015, 08:31 AM
dtvmcdonald's Avatar
There are different kinds of Easy Off ... which one?
