RCA TRK-120, without its TV chassis
Hi all-
I am now the happy owner of a TRK-120 that was recently discussed on the Antique Radio Forums. Its TV components were removed and replaced with a record player, perhaps as long ago as the 1950s or even late 1940s. The work was quite high quality, and it probably saved the set from being discarded entirely decades ago. The turntable was replaced with a newer one at a later date as well; there are two boards with different cutout patterns for each player. My intent is to restore/rebuild the cabinet parts that were modified or removed for the conversion, and then likely engineer a way to put a newer RCA TV chassis (probably an 8-T-241/KCS-28) with a 12-inch CRT in place while looking and hoping to eventually find an original chassis set.
Chris Quote from another forum: "(Antique TV collecting) always seemed to me to be a fringe hobby that only weirdos did." |
Glad that set went to someone who appreciates what it is. Your idea sounds great. A big job for sure, but worth it. It's the most iconic early TV. Good luck!
Great news! I was flipping around the Antique Radio site a couple weeks back and read the story
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
What a fun project!
John |
Not fun. I'm in the throes of a similar thing, though I now have all but the back.
My cabinet had the TV chassis mount hacked but the three holes are there .... as are some extras in the front that will need to be filled and reveneered. |
| Audiokarma |
Another thought, possibly heresy
, would be to use a VGA CRT monitor, again reversing the vertical yoke wires, and using a source like a cable box with a HDMI output port, and a HDMI to VGA converter module (many on that auction site we all love, the automated shopping linker will point you there). But to do this without irreversibly chopping up the cabinet, so you could install the proper chassis if you should get one.
Thank you all for the nice comments. I do know that the "retrofit" will be a bunch of work, and my main goal will be to do it without modifying the cabinet itself (and, first, I also have to get the cabinet back to its original configuration, too).
I already possess the 8-T-241, unrestored and in a poor cabinet, so that is why I picked it. Using another RCA for the replacement seemed to be a good idea to me, too, and I confirmed that its yoke is the same one that was used on a later 12-inch RCA set, the T-120. Depending on how hard I want to work on this, I will consider moving the components of the 8-T-241 chassis onto a new metal chassis the size/shape of the original TRK-120 chassis, but I do not know if this is even feasible. None of this is going to happen quickly, in any case, so I will take plenty of time to do a decent job of whatever works best.
At least that cabinet was very well kept. Sounds like a fun project.
If you are patient, an original chassis will show up. TRK-12/120s are the most common prewar set, with over 50 survivors. Eventually we will most likely be able to rebuild 12AP4s. Try not to make permanent modifications in the cabinet.
| Audiokarma |
Awrite !! Great story !
Benevolent Despot |
Steve, my intent is to not modify the cabinet at all (other than what has already been done, which I want to un-do as much as possible). I figure, the newer chassis and CRT/yoke are probably both smaller enough that I can make adapter brackets to bolt into the existing original nut inserts, remote-mount the raster controls under the proper holes in a replacement control panel, and maybe some type of gear/lever system to control the tuner from knobs/shafts in their proper place on the panel as well. "First, do no harm" is the way to proceed, and I am in no hurry.
Do you know if the silver-gray paint covering the inside of the cabinet is something special (heat-resistant or any other specific properties)? Where it has flaked off a bit, it looks pretty thick. I just noticed-this is a 50 Hz set, according to the label. I will have to study the schematic diagrams-does that affect the set's operation in any way, I wonder?
The paint is nothing special.
I have never heard of a 50 Hz version. Can you post the label? |
There's a few articles about it, on the various forums. ![]() 50 HZ transformers are fine on 60HZ. The chance of you getting another 50HZ chassis is rather slim, so it's no concern. |
I know that 50 Hz power was used in LA. However, I really doubt if RCA made a 50 Hz version of the TRK-120.
| Audiokarma |
