Old 05-27-2015, 01:30 PM
footlooseman footlooseman is offline
Rca 9-t-246
I just bought a RCA 9-T-246 for $15.
It looks really good except for the front safety glass.
I have a question about a sheet that fell out. Is it an asbestos sheet? If it is, then I will remove what's left falling down and leave the other two on the side alone.
Old 05-27-2015, 01:59 PM
Yep, Asbestos. Don't know why they needed to put fireproof material in a metal cabinet unless it was to keep the outside of it cool.
Old 05-27-2015, 04:15 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Yeah, I'd pull it out. I did on mine, and left the sides in place.
Old 05-27-2015, 07:22 PM
Tubejunke's Avatar
I guess it doesn't hurt to pull it out, albeit they put it there for some reason. Anyway, asbestos is completely harmless unless made what the E.P.A. calls "friable." To us that means ground on in some way to make it airborne. An example would be the many homes (like mine) that have asbestos siding. Not a problem. Even superior to modern replacement siding material. Unfortunately, I had some chucklehead contractor send "the boys" in to install a window that was the wrong size. To make it the right size the ground my siding with their circular saw WITH the old window out!!
I guess it could be a lawsuit, but who has the time? Most health hazards from what I have read are related to long term exposure anyway. Hope so
Old 05-27-2015, 08:48 PM
Nuke Nuke is offline
I wouldn't mess with that inside a closed area if I wasn't sure what it was. I read the problem with asbestos is when it breaks up, microscopic particles stay airborne for a very long time and can be breathed in. I also hear the greatest risks seem to be smoking and occupational exposure to it, and even then can be over decades. That stuff went into many things for along time, so you would think that just about everyone would die from it if it was just incidentally exposure. But I'm no expert and would be careful around anything I wasn't sure of.
Old 05-30-2015, 02:24 PM
Reece's Avatar
Reece Reece is offline
If you're going to remove it, get a spray bottle with water and wet it thoroughly before you touch it, put in a plastic bag and seal it up. That way no fibers can fly.
Reece
Old 05-31-2015, 11:24 AM
Notimetolooz's Avatar
I recently removed some asbestos tape around the windings of a phono motor. I think asbestos was a go-to insulation in days past. I would think the enamel on the windings would char before the tape got hot enough for needing high temp insulation. I removed it outdoors while wearing a respirator that I had. I think about the person that might have your project after me. The damage asbestos causes doesn't show up for decades. Those sheets might have been there to protect the paint on the metal cabinet. Another reason might be to deaden sound vibration from the speaker. A lot of plastic radios have pieces of foam, felt or cork between sections to prevent vibrations. Its the invisibly small fibers from asbestos that cause the danger and they can be generated by just brushing against it. I would carefully clean out any dust in the cabinet while outdoors.
Old 05-31-2015, 11:41 AM
It all depends on the state it's in. Solid house shingles are ok, the fiber cotton
looking stuff can cause problems.... Most of it is through long term workplace
exposure..... Not to worry though, it is still mined mostly in Canada, Russia,
and a few more countries where it still is an economic driver, products are sold
to third world countries to make corrugated roof panels mostly sold in India.....
Amazing that information about this stuff just don't put it off limits worldwide....
http://www.asbestos.com/mesothelioma/worldwide.php
I bet in some cases it was used as a heat barrier for the wood cabinet, or plastic.
Also for vibration. I bet you could replace it with a newer material, maybe some
floor linoleum, like the roll stuff. Maybe laminate a piece of foil over the top....
Old 05-31-2015, 02:22 PM
I think that the mining in Canada has recently stopped.
I realize I'm being extra cautious but hopefully our restorations don't go directly to a landfill after they leave our hands. Since the health effects don't show up for several decades if the only people exposed are in there sixties or later it probably doesn't matter. I aware of the case of lead for instance. Electronics for sale to countries in the European Union cannot contain lead (and some other things), that's the RoHS thing. I don't like using lead-free solder at all. It melts at a higher temperature and even then doesn't flow like the leaded solder. If you buy a lead acid battery in the US now, the cost includes a recycling fee, $3 I think. Perhaps in the future it will be illegal to sell anything containing asbestos or perhaps a fee would be involved. There are materials like fiberglass, ceramics and even some plastics that can replace asbestos.
Old 06-01-2015, 10:18 AM
bigaudioal's Avatar
Risk from removing that is probably minimal. But still could be SOME risk. Just take the set and remove it OUTSIDE to be safe. Don't want that stuff floating around inside your place. Also if you really want to be safe, where a respirator mask while doing it. Cannot hurt, only help.
-Al
Old 06-01-2015, 02:24 PM
It's possible to "safe" asbestos inside a radio or TV:
Asbestos in radios, what to do about it
1. At present, asbestos is known to be hazardous only if inhaled. Although there is some ongoing study on ingestion, the results are so far not alarming. Certainly less alarming than the results on arsenic, lead or cadmium.
2. Asbestos will become airborne only if friable (easily broken into small pieces). It becomes friable primarily if disturbed. There are three significant forms of asbestos as it was commonly used in consumer articles: Chrysotile, Amosite, and Crocidolite. Of these, chrysotile (white asbestos) is the most likely fiber to be found in that mat in your radio.
3. Asbestos that remains in place or can be made to remain in place is NOT hazardous.
Safing (encapsulating): Most (not all) of the asbestos used in domestic radios is included in a soft mat, either woven (rare) or non-woven (common). Usually it is held together with either a cementicious or gypsum-based binder together with several other fibers. The trick is to replace the binder with a more permanent and less mechanically vulnerable material. The EPA and OSHA recognize many sorts of encapsulants, including the binders used in both Duco Cement and Amberoid Cement. (Personal comment: I recommend Amberoid for its distinct color and the fact that I find it somewhat easier to use and less expensive that Duco. But the processes are identical. Amberoid will also maintain the insulating properties of asbestos, I am not sure if Duco will do the same.)
Mix the material of choice (Duco or Amberoid) with equal parts by volume of Acetone and soak this diluted material into the asbestos mat. It will re-glue the mat in place and bind all the fibers together. Allow to dry and soak again. Do this work away from flame or any source of flame. Do this work outdoors if possible. Do not attempt to brush, clean or vacuum the mat prior to treatment. Glue ALL of it down.
The times when the insulating mat are most likely to be disturbed are when the chassis is removed or reinstalled in a radio. Given that the original binders were not all that effective in the first place, and that they were made with deliquescent materials (gypsum or portland cements) it is very likely that some of the fibers will have become loose over the years, and may be disturbed when the chassis is moved or removed. If mice have inhabited the radio, this is a certainty. So, some initial cautions MUST be taken. And given that some here will neither admit to the hazard nor take any precautions, and that others here may not have the financial resouces to "have it done", what I suggest here is not offered as a way to eliminate a significant risk, but a way to reduce it at least in part.
First: Work out of doors. If you choose not to believe in any risk, it is still unfair to introduce asbestos into a house (or household) where it may remain a hidden hazard forever. Work over a large leaf-and-lawn bag if possible.
Tools:
1. Good particle mask. Must be effective from .1 to 10 microns (a human hair is about 50 microns in diameter). Because asbestos fibers are small and light, they can be suspended in the air for long periods. This is NOT a paper painter's mask. But once obtained, may be retained for multiple uses.
2. Small spray bottle filled with a 15:1 water-to-dish-soap solution. You will need a couple of ounces for the process, and about a pint at the end to soak the debris.
3. Strong paper towels... those that will not dissolve in soapy water.
4. Small, soft-bristled disposable brush. About 1/2" wide or smaller with at least 1" bristles.
5. Single-edge razor blade (not always necessary).
Spray the soap solution around the base of the chassis before removal. Make sure that the entire perimeter where it touches the asbestos is saturated and damp. This will hold the fibers from becoming airborne as the chassis is removed.
Remove the chassis carefully. Use the razor blade if necessary to cut loose the mat from the chassis. The idea is to leave the mat in place and not on the chassis.
Look on the chassis. If there are any visible particles of the mat on or in it, they must be collected and removed. For this, you will use the towels, the brush and PLENTY of the soapy water. A wet asbestos fiber will not become airborne. Soap is the wetting agent. Take your time and be thorough. Clean ANYTHING, even spider-webs or other material from the chassis. Be sure that it is clean.
Gently spray the inside of the radio cabinet with the soapy water. This would be those areas around but not covered by the mat. Wipe this down with the paper towels and repeat. The idea here is to capture any bits of asbestos that may have come loose from the mat.
Allow the cabinet to dry thoroughly. Soak the now-dry mat with the safing material as above. While the cabinet is drying, collect all the other detritus (brush, towels, razor, whatever) into the garbage/leaf & lawn bag. Pour the remaining soap solution over it so that it becomes a soapy mess. Seal the bag and bag it a second time. If there are ANY leaks in the first bag, bag it a third time. Dispose of the bags with your township's hazardous materials regulations, or in a regular landfill, NOT an incinerator or where the trash may be incinerated. Remove, double-bag and dispose of the mask filter also. You will use a new one for each session.
A bit long-winded as always, but the proverbial ounce of prevention covers many pounds of care in this case.
Above section on asbestos written by:
Peter Wieck
Old 06-01-2015, 03:41 PM
GlensterTX's Avatar
GlensterTX GlensterTX is offline
Is something burning?
I vaguely remember that spraying the asbestos sheet with hair spray (White Rain was the brand mentioned, I think) was one way suggested to keep the fibers from becoming airborne, FWIW.
Old 06-12-2015, 08:22 PM
6GH8cowboy 6GH8cowboy is offline
BBQ paint. Saturate the material and let dry. Do it several times. Don"t disturb asbestos in any way. I've treated it this way many years ago and its stilll rock solid, going no where. Good luck, and be careful!
