Old 06-16-2015, 11:43 AM
Tom S's Avatar
Tom S Tom S is offline
My CTC 11
Well aside from the Cataract The chassis is working fairly well. Now the CRT isn't great. Green and blue are down. If I could find a better one I'd install it. I don't know if I should fix the Cataract or just replace the tube. I had good luck with my Sencore Big Mack and the tube came back fair. My Beltron just couldn't do it. Same with my B&K 467 was the same. The tube is a 21FJP22. If I could just find one reasonable price I'd do it DSC05281.jpg
Tom Smrz
Old 06-17-2015, 04:23 PM
wkand's Avatar
wkand wkand is offline
I vote save the tube and fix the cataract. That is a nice picture, even if it is a little dim. The question you have to ask, is: Is the picture so dim that you hate watching it. Also, what is a reasonable price to you? I have seen FJ's go for $200 or more...
Old 06-17-2015, 08:38 PM
DavGoodlin's Avatar
Motorola Minion
That appears it would be an easy cataract fix. Maybe that alone will change any perceived CRT weakness but it looks good from here.
-Dave G
Old 06-17-2015, 08:46 PM
Kevin Kuehn's Avatar
Workin' Late Again
Hi Tom,
Have to agree with Dave, that the cataract is so far along that the safety glass may pop off without much struggle(easy for me to say ) I think most FJP tubes you find at this point are going to have similar cataracts. I guess another option would be a 21FBP22(non bonded external safety glass). But you'll probably have to harvest one from a less desirable set, which is easier said than done.
Old 06-18-2015, 09:26 AM
BigDavesTV's Avatar
BigDavesTV
I recommend trying to fix the cataract, and save the CRT! That tube still has usable life in it. I'd like to see a brighter picture showing the cabinet it's in! :-)
Old 06-18-2015, 09:48 AM
Originally Posted by Tom S View Post
Well aside from the Cataract The chassis is working fairly well. Now the CRT isn't great. Green and blue are down. If I could find a better one I'd install it. I don't know if I should fix the Cataract or just replace the tube. I had good luck with my Sencore Big Mack and the tube came back fair. My Beltron just couldn't do it. Same with my B&K 467 was the same. The tube is a 21FJP22. If I could just find one reasonable price I'd do it Attachment 187077
Attachment 187078
The picture looks pretty good and you're going to have to remove the cataract anyway.
If you do find another CRT, you can use that one in a less desirable set.
I have a Sencore Big Mack that I bought at a swap meet. The main reason I bought it is that is the only checker, I own that tests the GE Porta-Color CRT's and had most of the sockets. I never used the rejuvenate function.
Old 06-18-2015, 09:58 AM
from the looks of the whites in the pic I would say that the CRT looks pretty darn good. removal of that lens should be pretty easy as others have stated based on the degree of degradation of the PVA or what ever the plastic is.
Old 06-18-2015, 10:46 AM
I wonder if it's the original or replacement CRT?
Old 06-18-2015, 12:59 PM
IsthmusTV's Avatar
IsthmusTV IsthmusTV is offline
My guess would be that it's a replacement. I'm pretty sure that all CTC-11's originally came with 21FB's since they have the separate safety glass. Mine has its original 21FBP22.
Tom, I vote for removing the cataract too
-Clark
Old 06-18-2015, 07:51 PM
-Clark
Some CTC 11's had a separate safety glass and others did not. I Have one with the 21fbp22 CRT and another with the 21fjp22 CRT. The 11 does have a really good picture.
Old 06-18-2015, 10:58 PM
Workin' Late Again
My RCA field service guide states that CTC-11's could have come with one of three types of CRT, including CYP, FBP, or FJP. But there's no elaboration as to rhyme or reason.
Old 06-19-2015, 12:00 AM
rca2000's Avatar
rca2000 rca2000 is offline
I THINK...the first run of them had a CYP...then they went to an FB/JP tube.
Old 06-19-2015, 09:41 AM
I remember seeing that notation!
It must've been the real early production set that used the CYP. I've never seen one.
Tom S. would have to look inside to see if there is a serial number tag on the CRT matching the chassis tag.
Either that, or the CRT is a replacement.
Old 06-19-2015, 10:19 AM
radiomec's Avatar
radiomec radiomec is offline
Marco Bacigalupo
That type of tube is not difficult to fix the cataract problem, in these days I am working to a 21FJP22 of a Zenith tv set.
Old 06-19-2015, 01:51 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Brightened up the screen shot to see the cabinet a bit better. Hopefully Tom will post a photo of the cabinet.
-Steve D.
