Old 06-19-2015, 10:01 AM
RCA 13" 2002 model color set.
A friend found two later model RCA sets, that were set out for the trashman.
One is a clear case jail set, that has the HDTV converter board. Some bottom-feeder cut the AC cord off. After I replaced the cord, the set seems to work well, but the gray-scale is slightly off.
The other one is older and has to be used with a converter. The briteness was way down and the picture is all blue.
I want to get into the service menu and the instructions given on the internet done seem to work.
I just want to try it for S&G's.
