Old 06-25-2015, 04:42 AM
colectorad colectorad is offline
Inside A Panasonic EFD27LE CFL
After 20+ years of use, my family's first compact fluorescent lamp finally died. To mark the occasion, I de-soldered the terminal leads and took some photos of the (likely working) ballast:
Not long after this light went out, my bedroom CFL failed. In comparison, it was only 4 years old!
I'm in need of service manuals for the following:
Magnavox 19C315-CC, Emerson ECT-1300A (TM0110E), Sears 401.50300900
Old 06-25-2015, 01:16 PM
I've used the electrolytics from them, when I knew they failed prematurely, or the lamp was broken.
22mfd@ 200 volts.
Old 06-25-2015, 03:19 PM
It's so clean. No glue. The terminals are even wire wrapped.
Old 06-26-2015, 04:14 AM
markdi markdi is offline
markdi
put a new bulb in it
make it work for another 20 years
Old 06-26-2015, 09:07 AM
When they're turned on and left on, they'll last for many years.
I have three, that are left on continuousy, for around eight years. The last time they were off was the last power failure.
These are the inexpensive brand on sale at Aldi's.
Old 06-27-2015, 06:24 AM
22mfd@ 200 volts.
But, this one uses a 47uF (200V).
There's even a heat sink for the 2SC3972. It had a ~$20 MSRP for a reason!
Old 06-27-2015, 08:53 AM
It's a better quality unit all around.
The ones made now have mostly surface mount components, not the 'lytics of course.
Most fluorescent lamps will last a long time, if not turned on and off, too frequently. True with most electric discharge lighting.
Old 06-27-2015, 10:45 AM
Well made. I see what looks like a cracked coil ?
There are 2 blue ones side by side. It also has a 145 degree thermal
fuse in there.
My house was full of these when I bought it. I couldnt use
an AM radio so they all went to the dump. Switched to
the 130 V hard service bulbs ( still avaliable in all wattages ).
If nothing else it gives the finger to the government & GE.
Old 06-30-2015, 05:57 AM
Good eye. It's cracked, but still has good continuity.
fuse in there.
Still good, too!
Old 06-30-2015, 04:27 PM
I take mine apart after they quit to see what failed.I find the transistors blown apart in some and some diodes fried.I haven't see any caps blown apart in them yet.
I love the old ones like the Panasonic in the OP.I have some Philips/Sylvania bulbs that I purchased about 21 years ago and a couple still work.The current crop of bulbs are terrible and lucky to get 2 years out of them. the heat kills them.
