Old 07-10-2015, 11:17 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
More Pensburys are coming out of the woodwork....
Looky what I got yesterday!
Just an empty cabinet, but if there was ever an empty cabinet worth building a set into, it's this one!
Every mark on the cabinet was a spot of dirt. The thing is nearly flawless
Old 07-10-2015, 11:24 AM
SwizzyMan's Avatar
Restoring an admiral c322
Definitely not the same luck with my pensbury cabinet... Has extensive finish damage it flakes off and gets stuck on my palm when I handle it. Nice score.
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
Old 07-10-2015, 11:35 AM
Steve D.'s Avatar
Steve D. Steve D. is offline
Great find Tim,
Probably my favorite CTC-7 set. I hope you locate a proper chassis & 21CY.
Any idea what happened to the original guts?
-Steve D.
Old 07-10-2015, 01:11 PM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
That particular cabinet style must have been pretty popular in the day. I have one, too.
Old 07-10-2015, 05:13 PM
Kamakiri's Avatar
Originally Posted by Steve D. View Post
Great find Tim,
-Steve D.
My friend Ed has had this set for a decade or two. Unbelievably, it was a curb find from back then. No clue where the guts went....
Old 07-10-2015, 05:16 PM
Kamakiri's Avatar
I will say this.
I learned a lesson.
Never EVER ever ever ever ever take the screen mask of a CTC-7 apart, no matter how dirty it is. I thought it would take me ten minutes, it took me over 3 hours to get it back together. Parts popped out everywhere. I swore and yelled until I ran out of words to use and made up my own. Then I wanted to go find a Klingon dictionary and use THOSE.
I cursed David Sarnoff, his mother, his grandmother, and some other relations a couple times removed. And then I got mad.
Yes, I did get it back together. That job SUCKED.
Old 07-10-2015, 05:38 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Originally Posted by Kamakiri View Post
I will say this.
I learned a lesson.
As long as getting mad didn't involve keying the cabinet, I'd say you did all right.
Old 07-12-2015, 09:52 PM
BigDavesTV's Avatar
BigDavesTV
Very beautiful cabinet! Definitely worth building a set into! Yeah, I remember when I took apart and cleaned my CTC-7 Sanford mask assembly! After getting it back together, I said to myself "well, that ought to be good for the rest of my lifetime!" So far it's the oldest color set I've ever owned or worked on!
Old 07-13-2015, 07:37 PM
DavGoodlin's Avatar
Motorola Minion
Those safety glass trims were a bugger that year and in '59. There is probably an insufficient tutorial on how to finagle the ELL-trim and slider-thingys in the CTC7service manual.
I have two BW sets of this era and now I know how to clean the CRT, from the back after a total teardown, thanks for the tip, cap'n
-Dave G
Old 07-13-2015, 07:55 PM
If it's like the trim on my 10 it was hell to get off and on without bending anything.
Old 07-13-2015, 08:03 PM
too bad you're so far away, I have a CTC7 "Anderson" in a horrible cabinet.
Old 07-21-2015, 05:55 AM
Kamakiri's Avatar
So the VERY DAY I get done fitting a BPC into the cabinet, look what I come in to. Yep, unreal! A CTC-7 chassis with knobs!!!
Welp, looks like the BPC is gonna get tossed in the garbage and we begin fitting the REAL guts in . I'm still missing a convergence board and yoke, but I do have a line on a possible picture tube. Till then I may just stick a dud AXP in the hole.
Only problem is that this chassis isn't from a Pensbury, and it doesn't have a dial indicator. Can that be fitted to this chassis, or do I need a new tuner?
