Old 07-19-2015, 07:19 PM
Magnavox300's Avatar
..better in black & white
Disc capacitor with colored dots... Value??
Researched these caps, but can't find accurate info on them...
This disc cap has dots from left to right: brown, grey,grey,black, orange, yellow. I know the colors are the same value as resistors, but not sure which way to read it, or the starting point.
Anyone know how I should read this??
Old 08-02-2015, 08:50 PM
Hi, If you have not found the data you where looking for as of yet; check this site out tells you all about the dot codes on the caps, www(dot)smartdraw(dot)com/electrical-plan/examples/capacitor-code/ . Hope this helps you out.All the best, tom.j.fla
