Old 07-24-2015, 03:52 PM
jbivy jbivy is offline
complete novice
how do i extend a tuning shaft?
So im putting a late 50s fm tube radio into an empty 20s case. I need to extend the tuners shaft a good 5 inches. what will i need to do this?
Maybe using another piece of 1/4" rod, with a collar to connect them?
If im getting the terminology wrong, im sorry.
but any help would be appreciated. im making this radio appear stock from the outside, not changing anything internal. in case i find an original chassis.
"Good morning whiskey, good morning night. The end of the world is in my sight." Hank 3
Old 07-25-2015, 08:39 AM
I dont know where to get stuff off the shelf but a ham
flea market will have all kinds of stuff like that. There are
couplers that use set screws & shafts. Just be sure to
get the right dia. etc.
Old 07-25-2015, 12:23 PM
If the shafts are long flexible couplers may be worth using.
Old 07-25-2015, 09:15 PM
init4fun's Avatar
init4fun init4fun is offline
In the scrapping of old oscilloscopes , I have seen lots of shaft extenders being used . If you have any junk scopes kicking around you might have a look and see if your needed extender can be found in there .
Old 07-26-2015, 09:08 PM
complete novice
Hah, i dont even own an o-scope anymore. My heathkit scope was borrowed and never returned. I now have a rule, i will lend to friends, but never family. You can choose friends, but not family.
Luckily i found a shaft coupler for sale online. 1/4" to 1/4", so it will work fine for my needs. Now i just have to go to the steel store and get some 1/4" rod to make my shaft.
Old 07-28-2015, 02:22 AM
Another option would be to give your radio Viagra.
Old 07-30-2015, 10:06 AM
John Marinello's Avatar
<-- "Byron"
My '51 Zenith porthole chassis uses 2 shaft extenders, and they are quite long. They are the splined type.
