Old 08-06-2015, 12:50 PM
Banned
Late 1970s Lloyd's Stereophonic Flip-Clock Radio
Hello Everyone today I was out browsing around in the thriftstores and I found at the local Goodwill a late 1970s Lloyd's AM/FM Stereo Flip-Dial Clock Radio for $6 (I tried it out to see if the flip-dial clock still worked before I bought it at the store and nothing) so I bought it and got it home and took it apart and took the motor out and lubed it up and sure enough the motor shaft started turning again by hand so I plugged it in and turned the little flywheel on the back of the motor and sure enough the motor started working again so I put the motor back onto the clock mechanism put the clock back together and voila! A working Stereophonic Flip-dial clock.
So anyways I just wanted to post this because this is the first flip-dial clock radio I was able to get going on my own, and its the first one of these I've found in a while that was still in great shape that still had a functioning neon bulb for the clock and that was relatively easy to fix.
