Old 08-18-2015, 02:25 PM
drdave3 drdave3 is offline
Wards Airline GEN 1479A Schematic
I am looking for a schematic for this bad boy. The one in SAMS shows an entirely different model. However, I understand that perhaps a Sylvania TR_146BK is similar to the one I have.
Interesting that Wards would sell two different radios with the same model number.
Thanks in advance!
Old 08-19-2015, 01:49 PM
Banned
Thanks in advance!
Sears did the same thing they had a an old Stereophonic Tabletop radio from 1962 that had a built-in FM Multiplex that was I think a model 3058 or something similar to that and when I went to look up the schematic for it at the Sam's website the only thing that came up was a silvertone AM Clock radio from 1956 that apparently used the same model number so yeah, its not completely unheard of for a company to recycle a model number on a later model.
Old 08-20-2015, 09:09 AM
Hi guys, On Airline and Sears models you need to look for photofact info using the chassis number. These two retailers used model numbers over and over again and again. Likely other retailers did the same thing. All the best, tom.j.fla
Old 08-20-2015, 01:20 PM
If that Silvertone was series string tube, short and wide with side firing speakers, then I believe I have 2 of them.
Old 08-20-2015, 02:41 PM
Dont go only by the picture on a Sams, its the guts
that matter. They only show one of often a long list
that use the same chassis. Never saw much Wards but
Sears 4 digit model numbers were USELESS.
You can also look for an EIA number on the PCB & maybe
find who built it. A few pictures may work also. A TV is
easy to ID that way but radio would be a challange.
Old 08-29-2015, 11:51 PM
Banned
nope it didn't have have speakers built into it, and it wasn't a series string set either, you had to attach external speakers to it only and it had a phono input on the back using two RCA Jacks, and actually I was mistaken on the model number, the model number was 3025 which also crossreferenced in Sams to a 1950s AM only Alarm Clock Radio which the 3025 I have is a AM/FM Stereo Multiplex Tabletop Radio with external Speaker jacks (no built in speakers) and a phono jack and it had a Transformer in it for the power supply (wasn't series strung.) So anyways like I said previously it must of been common for department store brands to reuse their model numbers on their radios every few years or so, seeing as Sears and Monkey Wards both did it.
Old 08-30-2015, 04:16 PM
Mine has stereo phono input too....It would have made a nice mini system back in it's day with a small changer .
Old 08-30-2015, 05:03 PM
Banned
It still does, what are you talking about? hook up a CD player or a record player up to it and it still makes a nice mini system, especially with the SE 6BQ5 amplifier in it.
You'll need to show me a picture of yours because now you have me curious about the ones you have.
Old 09-02-2015, 12:24 PM
I'm all in with the chassis number. All I can find is serial and production number. Where else should I look?
Old 09-02-2015, 03:39 PM
WISCOJIM WISCOJIM is offline
Which Sams were you looking at that was wrong?
Can you give us some good pictures of the radio?
Old 09-02-2015, 06:35 PM
Banned
I know on my Sears/Silvertone Stereo there was a stamped metal plate riveted to the back of the chassis that had the chassis number engraved onto it, the number would look like xxx.xxxxxx which both Sears and Monkey Wards used pretty much the same suppliers for their chassises so more than likely it will start with a number like 101.xxxxxx or 524.xxxxxx so look for a stamped metal plate or paper label with a number similar to what is shown above, that should give you an idea as to what to look for in the Sam's Photofacts.
Old 09-02-2015, 07:09 PM
Sams says TSM-106, but I don't have that - I top out at TSM92
USN RET 22YRS (Avionics/Cal)
Old 09-08-2015, 04:06 PM
Just like this one.
Old 09-08-2015, 04:07 PM
Just like this one. See attachments.
Old 09-08-2015, 04:17 PM
Not at all similar to that Sylvania model either...
