Old 11-24-2015, 04:26 PM
pac.attack76's Avatar
Stuck in the past
2013 Emerson 32" LED model LF320EM4 help needed
Rescued this set curbside. Had no visual damage or defect so picked it up for my 10 yr old daughter. Set actually turns on, runs with good sound and button functions but no imaging. Screen lights up with good light but no displays, menu, volume meter or pic. Connected did and nothing but sound. Couldn't be the output connections since even the menu won't display. What should I look for and is this a simple fix or impossible?
Old 11-24-2015, 09:05 PM
Does it have a VGA connector, or DVI? I helped scrounge an LG LCD set from behind a Sports Authority store once - powered up, but no menu or display, and the backlights were good. Some software switch had turned off all RF/Video, and it was used as a monitor for something. Hooked up my computer, and I had a display. I got a firmware update from LG and installed it via stick at powerup, and the TV came to life, but wants a remote for menu and source switching. Seems to be a commercial product.
Just a thought that might help...
USN RET 22YRS (Avionics/Cal)
Old 11-25-2015, 07:29 AM
Stuck in the past
There's a blue vga plug back there. I'll have to see if I have a cable to try it.
Old 11-25-2015, 11:02 AM
MRX37 MRX37 is offline
Might want to check the LCD ribbon cable.
Old 11-25-2015, 11:05 AM
Stuck in the past
Cool, will check that too.
Old 12-03-2015, 12:57 PM
Stuck in the past
Lcd ribbon cable fine. No change. Now to find my vga cable.
Old 12-24-2015, 08:46 AM
Stuck in the past
After a full diagnosis, I've come down to replacing the main board. Video section. Actually contains all the hdmi sockets and connections. $22. Hooking up a did player and switching through the inputs, the buttons all work, sound works, no video at all.
Old 01-23-2016, 09:26 AM
Signal board, that's the board that has RCA, hdmi, cable connections. Or the connection link between the signal board and the tcon board.
