Old 12-02-2015, 04:01 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Princeton Ultra 20 monitor
Okay, not exactly a TV but worth a mention. I got this at a computer shop for 10 bucks. I have been wanting something like this for a retro-look PC build, and who knows what else it would be handy for with that jack pack.
I already had a NOS early ATX tower case, so this might get the Retrobright treatment.
Old 12-02-2015, 04:41 PM
MRX37 MRX37 is offline
Hope it doesn't have a whole lot of hours on the CRT. Otherwise nice find!
I mention that because every big monitor I found before LCD's replaced CRT's was used until the CRT got too weak to get a decent image, and the date on yours is 1996 so that thing probably saw use almost every day from 1997-2003 ish
Old 12-02-2015, 06:17 PM
slatton86 slatton86 is offline
Awesome! I picked up, nearly that same model some years ago. I used to play Sega Genesis and SNES with RGB, it has a great picture.
Old 12-02-2015, 11:14 PM
Jon A.'s Avatar
It seems to have plenty of life left. I'm using it for writing this post. Even at its lowest brightness setting it shows an image.
Old 12-03-2015, 07:22 AM
I wonder what that molex-type connector on the back is for?
Chip
Old 12-03-2015, 10:33 AM
jbattles's Avatar
jbattles jbattles is offline
jbattles
The first high definition big screens had that type of plug ins, if you could find the hdtv box from the late 90's to early 2000's you could use it as a high def tv. The first hdtv's had to have the vertical and horizontal sync with the rgb. I need one with vga output for my zenith.
Old 12-03-2015, 11:39 AM
Old 12-04-2015, 03:16 PM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
Sweet! That thing brings back memories of playing Doom and Starcraft on my old family computer! I should never have dump my old CRT monitor...well at least keep one for retrogaming because its not as fun to play Diablo 2 in 4:3 on a 16:9 LCD monitor.
Old 12-04-2015, 08:36 PM
Jon A.'s Avatar
By the way, how would I use it with the BNC connectors? I have no idea what those marked H+V/H and V are for, or if it can be used with just the RGB connectors or what.
Old 12-04-2015, 10:06 PM
The H and V are for horizontal and vertical sync
and no you can't use just the RGB connections. You need an RGB source with seperate horizontal and vertical sync. Or RGB with H and V on a separate line as that's likely what the "H+V" connector is for.
