Old 12-21-2015, 12:29 PM
Grossly overpriced "Edenpure" electric space heater.
Just for S&G's, I picked up an Edenpure 5000 BTU space heater at the thrift, I generally haunt. I just wanted to see, why fools would pay close to $400 for an electric space heater, with the same heat output as a $20.00 unit.
I plugged it in and it produced a little heat. It turns out, that it uses three quartz tubes for the heat source. Two are blown. The only good one looks like it's ready to blow.
There's various replacements, on Eplace. The cheaper Chinese KO's look better than the originals and a lot cheaper.
I'm not going to repair it right away, possibly never!
Old 12-21-2015, 03:14 PM
maxhifi's Avatar
maxhifi maxhifi is offline
I am a bit confused by what this is, so I looked it up... all I can say is anyone who goofed off in school so much that they don't understand the concept behind the first law of thermodynamics (i.e. conservation of energy), deserves to be ripped off by this kind of thing. Frankly I am surprised this company has sold even one of these things!
Old 12-21-2015, 03:33 PM
dishdude's Avatar
dishdude dishdude is offline
Do they still make this style? They worked the best.
Old 12-21-2015, 03:50 PM
maxhifi's Avatar
+1 on that
The ones I don't like are the small ones with noisy fans. Or the plastic ones which smell like an organic chemistry lab when they get nice and warm
Old 12-21-2015, 08:59 PM
If you want heat in a hurry, the pictured one will do the trick. I have one similar that's about 40 years old, American Hardware, made by McGraw-Edison, I think. Works great. I'm a real fan of the radiator style, too. I'm amazed at how long Eden Pure and their ilk have hung on in the market. I think of all those fake fireplaces and "Amish" heaters.
Old 12-21-2015, 09:29 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Arent the radiator style ones real energy pigs?
SR
Old 12-21-2015, 09:53 PM
maxhifi's Avatar
the radiator style heaters are good for heating a whole room to a constant temperature the fan ones are good for pointing some extra heat at yourself in a large room. I like both for their respective applications too. It's a shame electricity isn't cheaper, electric heat is great.
Old 12-21-2015, 10:05 PM
Had a 70's one that size...Twas the straw that blew the cabin's fuses one winter trip there...They were hidden in a junction box, and we could not find them....The relatives that did had a fun time since the fuses melted into their sockets when they went.
Old 12-21-2015, 10:25 PM
Banned
I saw one of these types of heaters at the Salvation Army a few weeks back, it was a Toastmaster/McGraw-Edison model from the 1960s I believe, I thought about picking it up but then my housemate would of thrown a fit.
Old 12-21-2015, 11:01 PM
Seems that they still have them on Amazon:
http://www.amazon.com/Comfort-Zone-C...radiant+heater
not affiliated,
Old 12-21-2015, 11:26 PM
Hi I have old electric wall heaters that the former owners of my house had put installed in the fifties when the boiler went south heaters were made by Hunter they still heat up the rooms great..Timothy
Old 12-22-2015, 09:49 AM
SR
1500 watts is still 1500 watts, no matter, which way it's used.
The radiator types are fine for enclosed areas, as they depend strictly on convection currents. I used one, set at 750 watts to keep an area above freezing.
You generally find them at garage sales, cheap as they're not very popular.
Old 12-22-2015, 10:09 AM
Another, all show, no go fancy wood end table style, I have is one I picked up on trash day, near my home.
The thing is in real nice condition. The only thing, that was wrong was the AC plug and U ground adaptor was all burnt up. The plug and receptacle, must've been in flames. How they let this thing run without smelling the burning wiring is hard to believe. It was the neutral terminal.
All it needed was a replacement plug.
One reason, the code now requires arc-fault breakers in most areas of the home, as an ordinary breaker, even a GFI breaker, won't detect this fault.
Old 12-22-2015, 03:51 PM
This is the most important thing to remember with electric heaters.
ALL of them will create the SAME amount of heat for the SAME number of watts consumed through the power cord. Some will do it faster, others will do it quieter (generally, the only reason to ever consider the "radiator-style" ones, which otherwise are more expensive and heavier than ordinary fan-and-filament ones). Others are "prettier", if that matters (Amish fireplace-style, anyone, if you want a $400 appliance to do a $40 job?). And, some are easy to use and easy to set to a known temperature each time you use them. But, NONE are "more efficient" than any others.
Old 12-22-2015, 09:16 PM
My wife likes to use a little fan-forced heater in the fall/spring when we don't have the pellet stove running. My mother-in-law went out and bought her a brand new one because it would be "more efficient". Of course, the old one is only 8 or 9 years old...and they both consume the same 1500 watts as something from the 50's.
