Old 02-15-2016, 09:51 PM
HighHopes HighHopes is offline
HighHopes
Olson vtvm
I need a schematic for this Olson TE-208 VTVM. It it has a metal case and is nice and big. The button type connectors have been removed. I usually change these to BNCs. I don't think Olson made anything themselves, so this might found under a different brand(s).
thanks - Steve
Old 02-16-2016, 10:54 AM
maxhifi's Avatar
maxhifi maxhifi is offline
I think that it should match the RCA VTVM schematic found in their tube manuals (for example, the RC-26) close enough to be useful, it uses the same tubes, and looks a lot like an RCA of the era. Probably the main problem is those grey electrolytic and paper capacitors, I bet if you change all of those and clean the switches it will work just fine.
Old 02-16-2016, 12:53 PM
They all seemed to use the same tube compliment.
The Olson model shown was actually a lot better than some of their earlier VTVM's, that were made by Accurate Instrument, which was some real junk.
My first VTVM was a Knight-Kit with a higher quality meter movement, made by Phaostron. Same tube compliment with a Mullard 12AU7.
I couldn't get excited about the probes that came with it, so I bought an Eico uniprobe.
I still have it, for like 54 years.
Old 02-18-2016, 04:09 PM
HighHopes
I was thinking this might be a Micronta relative? A predecessor maybe.
Old 02-19-2016, 09:56 AM
Some of the Japanese test equipment was made by Leader, before they made a name for themselves. Decent equipment.
Old 02-22-2016, 02:23 AM
HighHopes
Yes, it seems to be a very decent meter.
