Old 02-22-2016, 10:44 AM
Farlander Farlander is offline
Scratch remove technique needed
Ok, so I have(well soon to) have a 7 inch 1940s set, but one problem is the screen is kind of scratched up and it doesn't seem to be deep cracks, but visible surface scratches and I was wondering if anyone knows how to get off these scratches without replacing the screen.
Old 02-22-2016, 11:54 AM
Kevin Kuehn's Avatar
Workin' Late Again
You pretty much need to wet sand the surface level. For deep scratches I'd try strating with 100-120 grit paper, then working your way down to 1000-1200 grit. Follow that up with some Novus #2 polish, possibly follow that with Novus #1 if you're a perfectionist. The sand paper grit you start with depends on how deep the deepest scratch is. You can always start with finer paper, but then it takes a lot more elbow grease to get the deeper scratches out. I use blocks of firm foam with the paper glued on with 3M headliner spray adhesive.
Old 02-22-2016, 01:02 PM
Yes, start out with the finest grade of sandpaper that you think will remove your deepest scratches. This article describes how I polished the Lucite screen cover on my Admiral 24C15 (scroll down to "Restoring the Screen Cover"):
http://antiqueradio.org/Admiral24C15Television.htm
I started wet-sanding with 800 grade paper and ended with 2000 grade, followed by polishing with Novus #3 and #2. My cover didn't have deep gouges, just a lot of surface scratches and a cigarette burn.
Phil's Old Radios
Old 02-22-2016, 07:09 PM
Alright got it
Old 02-22-2016, 07:25 PM
decojoe67's Avatar
The first time I did it on an Admiral 7" screen I was sure I was ruining it. As you bring it back-up with finer grits it ends-up looking beautiful. Just be sure to sand the entire surface EVENLY and get the scratch all the way down with the rough grits.
