Old 03-12-2016, 09:30 PM
LovesZenith LovesZenith is offline
Platter Cosmetics
Hey guys, I have a Zenith Microtouch 2G changer. The changer works great, but the rubber cover to it is warped. Is there a way to fix this? I tried putting a book on the warped part (It was a little bit of a challenge to find a book small enough, yet heavy enough) but it did absolutely nothing after sitting overnight. Should I take the whole rubber cover off? I thought about doing that, but I was scared I would tear it or something. What would be the best way to fix this problem? I was thinking of squirting some glue under the problem area, and putting the book there again, but I wanted to ask to see if there was another way before I did anything.
Old 03-12-2016, 10:19 PM
The glue idea may be best. If you can heat it and soften it so it lays flat then weigh it down and let it cool weighted that may also work.
Old 03-26-2016, 09:55 PM
orthophonic orthophonic is offline
You can purchase a NOS exact replacement from thevoiceofmusic.com.
