Old 03-22-2016, 01:41 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Heathkit PS-4 Power Supply--Manual Available?
I just got a Heathkit PS-4 regulated 0-400V power supply that is nonfunctional, and the assembly work is pretty atrocious. I am thinking that this unit is a good candidate for a "rekitting" and reassembly.
Unfortunately, I didn't get the original assembly manual, and can't seem to find one on the web anywhere. I can only find the schematic, which is helpful for troubleshooting, but I really need the complete manual to do a rebuild. Does anyone have access to a copy they can scan and share?
Old 03-24-2016, 01:05 PM
Look up the manual for the heath IP32, not complete but might help.
Old 03-24-2016, 02:52 PM
Hi, Check out www.vintage-radio.info/heathkit/ for the IP-32 and schematic for the PS-4. All the best,Tom
Old 03-27-2016, 10:10 AM
N2IXK's Avatar
Technohippie
Thanks! I was able to find a complete IP-32 manual, and it appears 98% identical to the older PS-4, with the only electrical difference being the rectifier diodes (snap-in fuseholder type vs. modern axial leaded). That and a different color scheme for the front panel.
Currently rebuilding the unit, working from the IP-32 instructions.
