Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Introductions
Old 05-22-2016, 06:50 AM
Rich12 Rich12 is offline
capacitor question
Hi everyone I'm very new to restoration , if I need to for example replace an 8 350 paper cap what is the modern equivalent? For example I only see 10's in electrolytic caps not film. I also understand I can use higher voltage but everything I see in film is .47 or .68 I don't see any 8 or 10.
Old 05-22-2016, 06:24 PM
8 seems an unlikely value - can you post a picture?
Old 05-22-2016, 06:52 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
I agree that 8 uF is an extremely large value for a "paper cap", which are generally under 1 uF. Are you sure you aren't talking about an electrolytic?
Electrolytic caps generally have a VERY wide tolerance anyway (like -20%/+100%), so substituting the closest modern value is almost always acceptable.
8 uF was once a standard value but not anymore. Unless in a critical circuit, a 10 uF replacement would be just fine.
Old 05-22-2016, 09:14 PM
I believe 8.2uF is a modern standard value, but a 10 ought to work.
Old 05-23-2016, 10:18 AM
wkand's Avatar
wkand wkand is offline
8 uF Paper Cap?
Hi Rich12:
it is likely that the 8 uF 350 volt paper cap you reference is an electrolytic. If it is wrapped in a cardboard tube, this may be leading you to believe that it is a paper cap. As old-tv-nut says, a picture would be the best way to clear this up.
What we mean by paper is the dielectric material that separates the metal plates of the capacitor. In a tubular cap, the plates (usually some form of foil) are wrapped together, then sealed in ceramic, wax or plastic. The cap could have a plastic outside covering, and still be paper dielectric, and therefore needing to be replaced.
the value of the cap combined with its working voltage is the giveaway. You are correct in your observation that the poly replacement caps do not come in 8 uF values.
Make sense?
Walt Anderson
Old 05-24-2016, 12:51 PM
Capacitor
Here is a pic attached thanks guys!
Old 05-24-2016, 12:54 PM
Capacitor
Thanks Walt, I thought I was somewhat on the right track
Old 05-24-2016, 12:55 PM
The large value (8 microfarads) combined with a polarity (the positive side is marked) indicate that this is an electrolytic capacitor. A slightly greater value (10 microfarad), 250 volt or somewhat greater, electrolytic should work fine. Make sure the replacement is installed with the same polarity or you will have a loud bang and exploded capacitor contents everywhere.
Old 05-24-2016, 02:21 PM
Capacitor
Thank You!
