Old 05-31-2016, 11:58 AM
Rich12 Rich12 is offline
B&K TV Analyst
I have a model 1077B that needs test cables. I called B&K directly and they had no idea for something that old. The TL 5A they make is 4 mil, but that seems too small? The manual references replacement parts but not the jack size that I can see. Thanks
Old 05-31-2016, 12:24 PM
Normal banana plugs are about 4 millimeters (not mills). I believe that they are used for the connections other than the ones that use BNC connectors, or perhaps microphone connectors on the older models.
http://www.amazon.com/s/ref=nb_sb_no...3Abanana+plugs
tl5a cable:
https://www.google.com/search?q=b%26...HuovwFJ_7HM%3A
Old 05-31-2016, 12:46 PM
I just use banana plugs with clip leads on the ends and BNC scope probes for the RF on mine.
