Old 07-10-2016, 09:23 PM
What did broadcast color television look like in 1954 through 1957?
I suspect that today's modern color HD broadcast equipment, cameras etc. broadcasting today's OTA signals down converted to analogue and viewed on a properly adjusted CT 100, 21CT55, CTC4, CTC5, etc. will look much better then the original broadcasts back in 1954 to 1957 or longer. Am I wrong?
I was a bit too young (9) to have a vivid memory, but I remember seeing my first color cast about 1956. I remember, green tinted somewhat fuzzy, dim images. I think only the engineers and television technicians knew how to properly set up a color set back in those days. I know they were difficult to adjust and most people used rabbit ear antennas. You had to get the antenna just right, then fine tune and most folks over saturated the color control. The average Joe was probably perplexed and had to call a repairman a lot.
I do not know a thing about the original color cameras and their capabilities. So what did the original color casts look like starting in 1954?
Old 07-10-2016, 10:27 PM
sampson159's Avatar
sampson159
i remember the 1st time i saw a color broadcast.i think it was in 1955.new years day.the rose bowl parade.the image was magnificent!the overall picture was bright,clear and finely detailed with deep reds,emerald greens and the bluest of blues.it was in the window of hoermles appliance on parsons ave in cols ohio.few color programs available until the later 50s.the real coming of color televisio was in the 1963 to 1966 era.the coming of the zenith color sets.they raised the bar.
Old 07-10-2016, 10:49 PM
dishdude's Avatar
dishdude dishdude is offline
I guess my question for people that experienced both, was there a big difference between the early color broadcasts and the last analog color broadcasts 10 years ago?
Old 07-10-2016, 11:03 PM
I remember the color sets looked good in the Department stores, but not so good in people's homes.
The first time I saw color TV, it was amazing.
Old 07-10-2016, 11:58 PM
The big changes in color image quality were in several areas, some improving gradually and some in steps.
Color phase and intensity - tended to vary considerably with tube broadcast gear, becoming more stable as transistorized equipment came in.
Signal to noise: this was marginal with the original color cameras, taking a big leap when Plumbicons were introduced and another big leap with solid state pickups. Image orthicon noise, being independent of gray level, showed up strongly in the shadows due to being amplified there by gamma correction. Noise near black is also partly rectified in the picture tube, resulting in a raising of the picture average black level and hiding shadow detail. Besides the basic image orthicon noise, the early camera preamps were contributors, later improved by converting to transistor preamps. The noise level influenced how much gamma correction was practical, so the earlier cameras had much less contrast range, losing details in the shadows. This was compounded by the light-colored screens of the early color picture tubes, which reduced the contrast in the home unless you turned out the room lights. The lack of 100% DC restoration in receivers also contributed to contrast problems, dark scenes getting washed out towards gray and very bright scenes clipping the blacks. In a side by side comparison of pictures with late analog gear end to end vs. early gear, you would immediately be struck by the improved contrast and shadow detail.
As a result of all this, early cameras did not have full gamma correction, but used the same technique Kodachrome and Technicolor used of increasing the contrast to make up for the loss of contrast and color saturation due to all the effects that tended to wash them out. This works OK if the camera exposure is adjusted just right, but makes it more critical than it would otherwise be. This method of increasing saturation was necessary because the early cameras did not have color matrixing, which would have introduced additional noise. Plumbicon cameras included matrixing to make the color saturation match the CRT phosphors independently of gamma and contrast adjustments.
Geometry, color shading, yoke ringing (alternate light and dark bars near the left side of the picture), and RGB registration drift were all problems with the image orthicon cameras. RCA improved these things as time went on by building more precision orthicon magnetics. Another shortcoming of the early cameras is that the shading adjustments were added waveforms only, mainly affecting shadows, while Plumbicon and later cameras could have both additive and multiplicative shading adjustment. The high end studio cameras eventually had built in optical test patterns and control software that automatically adjusted all these things; plus, the lens characteristics were programmed in so that lens distortions were automatically compensated as the zoom setting was changed.
The problems with shadows, I think, were a main reason why the early color experimental broadcasts depended on a human subject (Marie McNamara, "Miss Color TV") for a final set-up check. Not only her skin tone, but especially her auburn (dark red) hair would have been affected by shading and RGB black level balance problems.
Analog video tape also contributed to noise and various beat patterns, again improved gradually over the years, and eventually replaced by digital recording.
If you want to see some of the early stuff, look for DVDs of the Bell Telephone Hour, the color episodes of the Howdy Doody show, and/or Peter Pan with Mary Martin. It is interesting to see what gross errors were hidden in the corners of the pictures in some cases, and were not visible at home due to the round picture tubes.
The early image orthicon cameras were very finicky to set up, and some studios' crews learned to do it better than others. I think it is generally acknowledged that NBC on the west coast got more consistently good results than NBC New York.
There were additional more minor improvements in going from Image orthicons to Plumbicons to solid state pickups. Image orthicons had problems with bright highlights (reflections from jewelry or brass instruments) producing a dark halo. In monochrome, this was deliberately used to give an approximate gamma correction, but was not good for color, where the halos would be in different colors. I remember seeing programs where someone wore a bright red dress or shirt that caused a cyan halo to spread around it and onto their face. Plumbicons had problems with extreme highlights causing "comet tails" trailing the moving bright spots. Plumbicons were also subject to differences in resolution of leftward diagonal lines and rightward ones, due to a phenomenon called "beam sharpening."
In a nutshell, things improved gradually or sometimes in steps over periods of years, and at a slow enough pace that most people could not accurately recall what the quality was like five or ten years earlier; but a comparison of the beginning and end should be instantly obvious to the most naive viewer.
Old 07-11-2016, 01:13 AM
I remember seeing the black flare around metal objects and bright objects that reflected into the camera lens on old black and white telecasts in the 50's. I think you could see it in some of the President Kennedy live assasination coverage if I'm not mistaken.
Old tv nut: Very interesting information. Were you in broadcasting or did you work for one of the major television manufactures?
I never saw color full time until it came into my home in 1966. The quality was generally very good, but I liked the Technicolor stuff the best.
You confirmed it, folks really did not see color on their brand new 1950's color sets like we can see it today on the same old restored sets viewing much higher quality color content. This also confirms my very early memories of color TV. I would very much like to see some of the old color content you mentioned.
Old 07-11-2016, 08:49 AM
dtvmcdonald's Avatar
I first saw color, as best I remember, not OTA but on studio monitors. This was 1954.
Later that year I did see it OTA quite a bit, however, the TV was at my uncle's house
a half mile from the tower, so the signal was perfect. This was all on 15GP22s.
I recall it looking just like it does today on my CT-100. I vividly remember the
image orthicon "halo" effect on B&W TVs, but never on the color ones, at least
not on locally originated shows (which most color ones were of course in those days
in Ft. Worth.)
Old 07-11-2016, 09:33 AM
Old 07-11-2016, 10:20 AM
Nine years with Motorola Consumer Products (until they were sold to Matsushita), and forty years at Zenith.
Old 07-11-2016, 02:04 PM
jsowers's Avatar
jsowers jsowers is offline
If you want to see some good early color content, tune in to the Dinah Shore Chevy Show on the Jewish Life Channel, if you're lucky enough to have that on cable. It's on at 2pm and 4am every day. So far the shows I've seen have been from 1959-1961.
No Chevy commercials, but they do sometimes show the ending where she sings See the USA in Your Chevrolet, doing her trademark "umm-wah" kiss, and they show the latest Impala or Corvair. They're not too strict on timing on this channel, so allow some extra minutes before and after the show to get it all if you're recording it.
I am no expert on early color, having first seen color TV in 1969, but the color reproduction looks very good to my eyes, considering the age of the shows. You can tell they tried to be very colorful in their sets and costumes. The show I saw the other day with Dinah singing Deep Purple would be great for showing off an early color TV. It was the 12-6-59 episode with Carl Reiner, Mary Costa and Mahalia Jackson.
I do notice the black "blooming" areas around reflective things, which may be more a result of early videotape reproduction or it could be coming from the cameras.
Old 07-11-2016, 02:18 PM
lnx64's Avatar
lnx64 lnx64 is offline
It's 1958, but I found this.
https://www.youtube.com/watch?v=QKqHZcXvUAs
Old 07-11-2016, 03:36 PM
Originally Posted by jsowers View Post
If you want to see some good early color content, tune in to the Dinah Shore Chevy Show on the Jewish Life Channel...
Thanks for the info. The black halos are definitely a well-known image-orthicon effect.
Old 07-11-2016, 03:37 PM
sampson159's Avatar
sampson159
as television technology progressed.so did the color picture.the first zenith roundies had outstanding,movie like quality.rca wasnt not quite as good but very acceptable.the real highest point for me was the hybrid and early solid state days.zenith,sylvania,philco and of course rca.they all produced amazing pictures with the sylvania taking the nod to me.as far as quality,zenith and rca were the top servicewise.the broadcasting quality advanced too.to see a movie shot in technicolor or perfect pathe on a 25v hybrid or solid state set was the pinnacle of color television to me.always and still amazed at those sets.when i fire up the e48 superset or my flat chassis to watch a movie,it still get the same feeling as i did back then.
Old 07-11-2016, 05:17 PM
Yes. This is a perfect example of what old tv nut was talking about with the flares.
Old 07-11-2016, 05:47 PM
That channel is not available here. I remember watching the Dinah Shore show but in b&w. I had to go to department stores in the 50's to see color TV.
