Old 07-17-2016, 03:41 AM
austvarchive austvarchive is offline
Marconi Camera CRT Cataracts
Some photos showing the CRT cataract problem in a Marconi Mark 8 Color camera studio viewfinder.
Its actually turned into a semi liquid state, and begun oozing out into the casing and electronics..not a good mix!
It smells pungent, like paint stripper!
Be aware of this issue with old cameras! - but do not attempt to remove unless you are trained with handling CRT's, these are under vacuum and can be dangerous.
