Old 07-22-2016, 04:16 PM
Lifeguard Lifeguard is offline
Need SONY KV-5100 Antenna Part #
Can someone tell me what the Sony OEM part # is for the Telescopic Antenna on a 5" Trinitron KV-5100? Did the KV-5000 and / or other models use the same antenna? Trying to source a replacement.
Thanks!
Old 07-22-2016, 05:06 PM
IIRC they used a stud rod. If the base is OK & its a stud
type you can use a rod off the common AN18 ( IIRC part # )
2 antenna plug in ears. They were used on almost all 12"
& above color sets in to the 80's. A picture would help also......
Old 07-23-2016, 12:44 AM
Old 07-23-2016, 03:13 PM
I don't have the TV in front of me so no pictures as yet. I do know it's wider in diameter than most and it fits into a sort of socket that allows the rod to rotate.
Old 07-26-2016, 12:19 AM
I was able to buy a replacement antenna from directly from Sony about 10 years ago. It was expensive, but I was amazed they still had the part in stock. Sony used to have all kinds of old parts available. I'll look up the part number and post it. Unfortunately, Sony no longer sells parts directly to the public, but it's possible one of their parts dealers can get it if there are any left.
Hey Andy... Were you able to find that original part #????
Old 07-27-2016, 03:47 PM
Old 07-27-2016, 05:19 PM
Once upon a time I had that antenna from a set I scrapped...I can't remember what became of it, but I did give much of that set's remains to user Arcanine. It might be worth checking with him.
Old 08-10-2016, 03:50 PM
Union Electronics (UED.net) was the last to have them - Russell Industries made a replacement, POR-10H. Note that all the Sony numbers for 7 or so models all cross to the same part number, 1-501-156-99 or 1-501-156-XX (XX=don't care in Sony lingo...).
https://www.ued.net/ued/viewItemActi...e=SNY150115100
I have one of the POR-10H, New in the package...$22 + Shipping. PM me if interested.
BTW, most appearance parts were dropped by Sony after 3 years, thanks to the cancellation of the FTC "life or 7 yrs" rule" from the 60's... Sony stocked electronic parts sometimes for more than 20 years past their prime - the SG-213A is an example - deleted in the early 00's.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 08-31-2016, 04:06 PM
Cheers,
I've sold it, no longer available. Thanks, George.
