Old 08-23-2016, 04:12 PM
pac.attack76's Avatar
Stuck in the past
1955 Zenith 20" floor model
Did a little work on this set and this is all i could come up with. Pretty good sound and somewhat of a pic. Is this worth fixing? I hate to toss it but space is limited.
Genesis does what Nintendon't
Old 08-23-2016, 06:16 PM
Of course it is worth fixing!
Define "a little work" please.
To me it appears that the cathode bypass lytic on the vert out is probably open. Any original caps in the vertical (the B+ lytic feeding the vert output is another prime suspect) could potentially be causing this...If they have not been changed then change them. If caps are new check resistors and tube(s) in that stage and see if the vert linearity, and or vert size/height do fix it.
Old 08-23-2016, 08:45 PM
Stuck in the past
I ask if its worth fixing as ive tried a few times to sell it and even at a mere$25, theres absolutely no interest. As for keeping it, i'd like to if i can get it finished. As for the work, more or less just tinkering at this point. The most testing ive done on it in two years. Got a pic up with sound and centered all the adjustments best i could. Caps are all original. Is there a kit i can get or will i have to take down all values and types and get replacements for all?
Old 08-24-2016, 12:43 AM
Absalootly!!
To me it appears that the cathode bypass lytic on the video out is probably open.
You meant so say vert out, right?
Old 08-24-2016, 03:06 AM
David Roper's Avatar
console lover
This may be nitpicky, but it's a 21" set. There were such things as 20" sets, briefly, in 1951-52, and they were immediately superseded by 21"ers.
tvontheporch.com
Old 08-24-2016, 06:57 AM
Yes I did. Thanks for pointing it out.
Old 08-24-2016, 07:00 AM
No kits for sets this old. You gotta order them individually. If you got the schematic you can pull them from the parts list otherwise read them off the chassis. I may have a copy if you list the chassis number. Only paper and lytics need to be changed.
Old 08-24-2016, 07:28 AM
Fix the poor old thing. Its got a nice strong jug.
As far as selling it you have to find the right
person & raise the price ! Then market it.
Old 08-24-2016, 08:11 AM
Stuck in the past
Soon as i get that back off again, ill get that number.
Old 08-24-2016, 08:19 AM
Stuck in the past
Chassis is 19L27
Old 08-25-2016, 11:42 AM
Stuck in the past
Do you have anything for that number?
Old 08-25-2016, 01:55 PM
Remind me again in roughly 3.5 hours. After I get home from work I'll be around my service literature.
Old 08-27-2016, 04:44 PM
nasadowsk's Avatar
Damn does run fast…
The basics on that set work - flyback, sweep, crt, etc.
Your set can be fixed, but it'll take some effort. It's not hard and can be learned, though. It will then perform like a 50's B&W TV, which is actually quite good.
Old 08-27-2016, 06:07 PM
Stuck in the past
I didn't get back on till today. Are you where you can get to them?
Old 08-27-2016, 06:38 PM
The Sams website says the manual for Zenith chassis 19L27 is 232-11:
https://samswebsite.com/en/photofact...index/id/14447
If nobody here happens to have it, you can order direct from Sams or watch for a copy on eBay.
As others mentioned, replacing the electrolytic & paper caps will likely fix the picture problem and also make it reliable/safe to play regularly. If you haven't replaced caps before, this article provides basic info about that:
http://antiqueradio.org/recap.htm
This article describes some other basic restoration procedures:
http://antiqueradio.org/FirstStepsInRestoration.htm
The following page lists a bunch of TV restoration articles. None of those sets is exactly like yours, but if you skim one or two articles, you'll get an idea what's usually needed to get one of these old sets working well:
http://antiqueradio.org/televisions.htm
Regards,
Phil's Old Radios
