Old 09-01-2016, 07:04 AM
Kasanay Kasanay is offline
MP Television ????
I came across a few sets that were made by a company call: MP Television. They were located in Fairfield, Conn.
I found these while researching MP Engineering Corp. - maker of audio gear back in the 40s, 50s and 60s.
I have three different models. I also have the original, hand drawn, full size schematics.
https://www.dropbox.com/sh/zb7852nkp...vnm-kU4Qa?dl=0
Any info would be appreciated.
Thanks,
Joe Y
Old 09-01-2016, 08:57 AM
earlyfilm's Avatar
Eternal Member
Rider published service information for a probable 12 inch model in Vol 5 and for probable 16 and 17 inch models in Vol 8.
It might make an interesting comparison. (I don't have a copy.)
James
Old 09-03-2016, 06:05 AM
James
Thanks for the tip. I know very little about televisions (my obsission is tube audio). Until this post, I was not aware of the Riders manuals. Are the volumes you mension available online?
Thanks,
Joe Y
Old 09-03-2016, 10:29 AM
Thanks,
Joe Y
Both sets are similar, slight differences in vertical sweep.
Four stages of IF, Standard Coil penthode tuner, simple AGC with a local-distance switch, intercarrier audio, synchro-guide horizontal and 5U4, power transformer power supply.
Appears to be a set for custom installation, per the instructions.
Old 09-04-2016, 10:06 PM
Diesel,
Can I ask where you found this information? Was it in the Riders Manual? I would really like to see where it was published.
From what I was told, there were relativity few of these made. I also know MP made a 20" version that they called "The Super Twenty"
I'd be interested in knowing if anyone has an MP Television or has ever seen one.
Thanks.
Joe Y
