Old 09-05-2016, 04:28 PM
Console User Console User is offline
1991 Zenith Console Telvision Horizontal
I need some advice on if and how you can go about adjusting the Horizontal on a 1991 Zenith Console TV. My Zenith Doesn't have the Adjustment on the back near the bottom of the TV like my RCA TV does.
I believe my horizontal on the TV currently is a little out of Adjustment.
Old 09-05-2016, 06:54 PM
MRX37 MRX37 is offline
Unlikely but you might have a service menu that can be accessed. If not there might be an adjustment inside the set. However the issue might be a bad capacitor or another part in the horizontal circuit that's drifting out of spec.
Old 09-06-2016, 06:04 AM
If you want help, a little info goes a long way....
http://www.videokarma.org/showthread.php?t=265964
USN RET 22YRS (Avionics/Cal)
Old 09-17-2016, 04:06 PM
Duane's Avatar
Duane Duane is offline
Are talking about the horiz. position or horiz size?
Old 09-18-2016, 11:20 AM
OP hasn't visited since his original post. No model number, no help from me. Years are USELESS.
OP:Simply post the model number (or a chassis number) and help will flow.
