Old 09-25-2016, 02:18 AM
john116 john116 is offline
Australian made GE television
Hi - attached is a picture of a GE television, made in Australia, and purchased in 1969.
Just wondering if there is an American equivalent/similar looking set, and what that set's model number is?
Thanks,
Old 09-25-2016, 05:46 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
Pic? Where?
Old 09-25-2016, 08:50 PM
Pic added correctly this time. Apologies.
Old 09-26-2016, 08:49 AM
Celt's Avatar
Peanut Head
Good looking set!
Old 09-26-2016, 09:45 AM
Thanks,
It looks like a 1966 19" GE portable. IIRC, the thumbwheel knobs were for brightness, contrast and vert hold.
Ours had the VHF tuner on the top and the UHF tuner, where your VHF tuner is located.
Ours had mostly compactron tubes and series string, low B+ hot chassis.
Reliable, good performing sets. They even made a hospital model, with a big isolation transformer and grounding line cord.
Old 09-26-2016, 03:03 PM
Hi,
The Australian version also uses mostly Compactrons, series string heaters, but with a transformer as well (I assume to drop the 240v here down to 120v or so). The front panel actually has UHF and VHF embossed in it, although obviously there is only a VHF Tuner. Australia didn't have any UHF back then. Also the rear panel has two vacant holes marked UHF for the antenna terminals. Circuit diagram available here for anyone interested:
https://vintage-radio.com.au/docs/ge...it-diagram.pdf
Old 09-26-2016, 06:03 PM
Hi,
Thanks for including the circuit diagram. The circuit looks the same as the USA version. The only thing, I don't recognize is the 9BJ11 1st and 2nd IF tube, but then I'm going by memory.
Old 09-26-2016, 10:26 PM
Telecruiser's Avatar
Telecruiser Telecruiser is offline
Didn't Australia use 625 line 25 fps TV? Would an American TV work by just tweaking the horizontal and vertical, or were more modifications needed? Or for that matter, did Australia use something different? I was in Australia back about 1973 and everything was black and white, but I thought the standard was more or less a monochrome PAL system Inquiring minds want to know...
Old 09-27-2016, 02:03 PM
Originally Posted by Telecruiser View Post
Didn't Australia use 625 line 25 fps TV? Would an American TV work by just tweaking the horizontal and vertical, or were more modifications needed? ...
That, along with a different sound suncarrier frequency, would be about it. And the tuner needs to tune different frequencies.
Old 09-28-2016, 03:34 PM
Australian standards
Hi, yes, 625 lines, 25 fps. My small collection of US standards monochrome sets run nicely with those standards, but these days using a digital set top box and an american sourced RF modulator. Minor tweaking of vertical and horizontal is all that is required.
Old 09-28-2016, 09:05 PM
That's what I thought, but I wanted to check if I remembered correctly. Thanks for the refresher!
Old 09-29-2016, 07:24 PM
United States model is M400BGR etc, DB chassis there are a few differances but otherwise the same down to the 9BJ11. All the best,Tom.J
Old 09-30-2016, 02:43 AM
Thanks
Tom, thanks for the specific model number. Would love to see a picture of that model, and also, if anyone has one for sale, would be keen to buy one. I'd pay for shipping to Australia of course.
Old 09-30-2016, 02:10 PM
H... Circuit diagram available here for anyone interested:
I wonder why they didn't have a tap on the secondary of the power transformer to feed the heater string, instead of having a dropping resistor. Less waste heat to vent.
Old 09-30-2016, 05:27 PM
Cheaper probably.
