Old 10-28-2016, 08:12 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Vertical linearity on a CTC-11?
Anyone know how it's adjusted? Just got done with a recap on this Philco 11 clone, and I can't seem to find the control.....
Old 10-28-2016, 08:26 AM
Pull the knobs off those four lower controls, the adjustments are through the shafts of two of them, can't remember which two off hand.
Old 10-28-2016, 11:17 AM
Kevin Kuehn's Avatar
Workin' Late Again
I think on the RCA 11 Vert Lin is inside the contrast(center) control shaft. Height inside the tone shaft. Color killer threshold inside the vertical hold.
Old 10-28-2016, 11:30 AM
The Sams manual can be downloaded from ETF at:
http://www.earlytelevision.org/tv_sc...ams_color.html
Regards,
Phil's Old Radios
Old 10-28-2016, 12:13 PM
Kamakiri's Avatar
I actually DID download it, but only glanced at the back controls diagram. As soon as you guys chimed in, I remembered that my 5 has controls buried inside shafts too. Sneaky sneaky! Thanks guys, that did it!!
Old 10-31-2016, 10:58 AM
That arrangement seemed to make more sense! It's easier to see the screen, sitting in front of it, instead of using a mirror.
It must've been a cost factor. The dual pots were more expensive, than the singles.
Old 11-01-2016, 03:32 PM
DavGoodlin's Avatar
Motorola Minion
Philco did this "stealth" move more than RCA did, even on their BW portable sets.
-Dave G
