Old 11-04-2016, 10:30 AM
DavGoodlin's Avatar
Motorola Minion
How to fix loose CRT base - CTC11-12's
Ive got three tubes with different issues but all have a loose base. The '72 RCA colorama 21FJP22 that had its base skirt busted off goes first. Ill start by carefully extracting the solder from the pins of a donor base off a dead Sylvania 21FK and then double extra careful removing the busted-in-half base on the tube under restoration. I do not feel like re-soldering a lead busted off at the glass
Now what do I do? It needs to be non conductive, heat-resistant yet bond glass and phenolic. I saw a thread about a recipie for the crunchy caramel-colored glue-filler somewhere
-Dave G
Old 11-04-2016, 10:33 AM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
I used clear nail polish on a tube before.
[IMG]
Old 11-04-2016, 12:34 PM
I use Permatex Flowable Silicone 81730 Windshield & Glass Sealer.
https://www.farmandfleet.com/product...ss-sealer.html
Old 11-04-2016, 12:36 PM
Old thread with recipie here:
http://www.videokarma.org/showthread.php?t=261452
You might want to scale down the proportions somewhat!
Old 11-04-2016, 02:38 PM
DavGoodlin's Avatar
Motorola Minion
Thanks for the suggestions. Nail polish sounds interesting also. Non acid seems like its also called sensor-safe on the silicone stuff.
Checking on availability with a chemist now...have to scale down weights on those ingredients for the goo, Ill sure try it.
-Dave G
Old 11-04-2016, 10:28 PM
I can understand being curious about the old glue recipe from a historical viewpoint, but why would you want to replicate the same stuff that is now falling apart and causing problems?
I'd use a modern product. Some things actually HAVE gotten better during the last 60 years
Phil's Old Radios
Old 11-06-2016, 01:44 PM
DavGoodlin's Avatar
Motorola Minion
Phil's Old Radios
True, I would not think repeating the same formula obtains a different result. I am hoping that there are no heat and conductivity issues. The glass sealer Bob recommends was available at an auto parts franchise locally.
I plan to drill 3-4 tiny holes around the circumference to inject the stuff.
-Dave G
