Old 12-24-2016, 12:58 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Wide load
Don't get me wrong, I like low, wide cabinets.
This is the other set that came from Yarmouth. I can't find a manufacture date on it, but the 25VBEP22 bears a date code of 7430, so I assume the set was made later that year. It must be a model made for the Canadian market because I've seen continuous UHF tuners on other post-'73 Canadian sets. It's a remote set and I actually got the remote this time. The model number is 62CS73R. I've taken a bunch of pictures, hopefully someone can identify the chassis.
Any safety cap issues with these sets? I haven't tried to power it up.
https://www.flickr.com/photos/154129...57687971074545
Last edited by Jon A.; 08-23-2017 at 07:13 PM. Reason: Switched Flickr account, updated URL.
Old 12-24-2016, 10:50 AM
1975ish, right? Sanyo made earlier consoles, but nothing that large until the mid-70s. The distributor I worked for distributed Sanyos from ~1973-1978, and one thing was clear - consoles were not a big seller. Sanyo made sets during that era for Sears and Channel Master (A 91C90 series CM set is still going locally....).
Sanyo never used a US CRT supplier - your tube is probably a rebuilt one installed later. Sanyo, Clinton, and Hitachi CRTs - that's all I've ever seen...
USN RET 22YRS (Avionics/Cal)
Old 12-24-2016, 12:14 PM
30th week of 1974 = last full week of July, so, if original CRT, set is very likely a '75 model
Old 12-24-2016, 12:18 PM
That's the biggest screen, biggest cabinet deltagun Japanese set I've ever been made aware of.
Old 12-24-2016, 01:28 PM
Jon A.'s Avatar
It's a RCA 25VBEP22. That's what is printed on the transistor map as well. Weren't they all made by RCA? .
Woohoo!
Old 12-24-2016, 07:09 PM
I am 99% sure this is a Hitachi chassis. Compare it to the
one you junked. The connectors & yellow placement ID tags
are a giveaway. Build style / layout also fit this era of Hitachi. Look for the rising sun logo on the PCB's.
Never seen a Sanyo SS console til the Sears ones of
the early 80's on. They were an excelent chassis.
If there is a US counterpart the model would probably be
52CS73R. First letter or Sanyo models is screen size BACKWARDS !
62C is 26" Canadian
52C is 25" USA
91C 19"
31C 13" etc.
Both Hitachi & Sanyo also sometimes had chassis ##'s. Sanyo on
the back but dont remember them inside.
Hitachi on a tag usually on IF shield & sometimes on back.
Merry Christmas
Zeno, Sharon & Luck Strike the cat.
Old 12-24-2016, 07:10 PM
sry first NUMBERS !
Old 12-24-2016, 11:51 PM
Jon A.'s Avatar
This chassis looks quite different from that of the junk Hitachi, but those wire tags did make me think Hitachi. It reminded me more of Maggie's T995. The connectors are different and I see only one carbon composition resistor whereas the Hitachi chassis was loaded with them. Two days ago I packed up what was left of the Hitachi and sent it to another collector. No rising sun logos on the Sanyo boards that I could see. There are some Hitachi transistors but even my Electrohome console has a Hitachi HOT.
Merry Christmas right back to all of ya.
Old 12-31-2016, 04:26 AM
Jon A.'s Avatar
I couldn't find anything that looks like the safety caps I'm used to seeing, so I threw caution to the wind and powered up this boat. It seems to be fine but I noticed something rather odd: It has a 25VBEP22 which I know is the type of CRT it originally had, and I believe they have extra lead in the glass to handle more HV. However, when I checked the HV it was no more than what I saw produced by a Zenith 25DC56. I'm wondering if anyone knows of any sets equipped with the 25VBEP22 or the 25VCXP22 that normally drive the CRT at about 25Kv.
Also, there's no VRT, at least not one like those I'm familiar with. Might this be a hot chassis set?
Old 12-31-2016, 07:46 AM
kf4rca kf4rca is offline
Never seen a Sanyo console here in the South.
Old 12-31-2016, 07:51 AM
Check the red print labels on the big heat sink. Bottom one says chassis is connected to one side of the power line. Use care with this one,but nice find hope you find service manual for it. All the best,Tom.J
Old 12-31-2016, 01:04 PM
Jon A.'s Avatar
Oh yeah, I see it now. No problem, when I have to poke around in there I'll run it through the Powerite.
Oh, I inserted the HV probe before plugging in the set for HV measurement.
