Old 01-07-2017, 12:22 AM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
Replacing Mica Caps
I know that conventional wisdom is that mica caps rarely need replacement, but I've come across several in recent months which positively read fifty percent--or more--higher than they're supposed to. And I also sometimes break off the leads. When I do replace these, what should I use? I've been using 630V polystyrene and 500V silver mica caps--whichever gets me closed to the desired value. Any better suggestions?
Thanks,
Henry
Winky Dink
Damn the patina,
Full speed ahead!
Old 01-07-2017, 06:35 AM
Me, I'd stick to the dipped silver micas, with possibly NP0 ceramics as a backup. The silver/clear polystyrenes like to crack and open up. We serviced a lot of Sharp and Hitachi B/W sets back in the 80s that had only one problem - the polystyrene caps in the horizontal oscillator would crack, change value, and we'd replace them with "close in value" silver micas - they had some odd values like 700pf and 850pf in the larger screen sets.
NP0-tempco ceramics don't have a drift factor - so are suitable, stable alternatives to silver mica caps.
USN RET 22YRS (Avionics/Cal)
Old 01-07-2017, 10:23 PM
Winky Dink's Avatar
Thanks. I will heed your recommendations.
Winky Dink
Damn the patina,
Full speed ahead!
