Old 01-21-2017, 11:57 AM
Restoring a RCA 21CT55
Well over a year ago, we purchased a 21CT55 from the Early Television Foundation. It has been a long haul, 470 days and the restoration is completed.
Steve McVoy, Dave May, Bob Galanter, Kevin and Mike Doyle (edit: I left out Walter) all members of this forum helped with the restoration. I want to thank them very much. It could not be done without your help.
You can see screenshots along with a chronological accounting of the restoration from day one at this link:
https://visions4netjournal.com/vinta...p-carousel-967
Moderators, apologies for the large screenshot. Can you reduce the size?
Old 01-21-2017, 01:40 PM
Old TVs are better!
Very good job. Looked at the pictures on the visions link, and the color is great. I have a 21CT55 also that I restored, and is working as well.
Old 01-21-2017, 01:52 PM
Thanks Walter. I forgot to acknowledge you. You also helped me isolate the power switch problem.
I followed your 21CT55 restoration thread. Was inspired.
Old 01-21-2017, 02:25 PM
Wow! Wonderful restoration and documentation of the restoration of one of the very most desirable of the milestone color sets!
Old 01-22-2017, 03:37 PM
Old TVs are better!
Out of curiosity what was the problem with the power switch. If I remember right we chatted online and you said it was dead completely. I suggested the power switch and some of the places you could check it out without pulling the chassis. Was it the switch itself as I suspected? If so did you find a replacement switch with volume control? Also is your cabinet the original finish? Looks really good in your first photo. Mine was really sun faded, (especially the top and one side), so I finished it with Minwax stain. I really should have had the cabinet professionally refinished, but was afraid to remove the 21AXP22 as I didn't want it to go to air. Sanding and stripping the cabinet (with the CRT in place) also felt very risky because of the vibration if I had left the CRT in the cabinet. Maybe someday I'l be brave enough to remove the CRT and take the cabinet to a pro refinisher.
Old 01-22-2017, 04:29 PM
Tomcomm's Avatar
Tomcomm Tomcomm is offline
Welcome to the 21CT55 club. I would like to see some full screen size, screen capture shots. I assume your included screen shots were thru the full RF/IF systems, right? It would be interesting if you could compare them with your computer monitor screen shots. Seems you have some color aliasing contamination in the small detail. Looking forward to your further screen shots.
Old 01-22-2017, 04:41 PM
Walter,
You were right, it was the power switch that failed. We found out the switch was a replacement sometime in the set's history. It was incapable of handeliing the high current on power up. The switch had a 3 amp rating but the transformer was drawing higher current. Mike suggested we install a relay to draw the current and lessen the load on the switch which was replaced to the correct value. This was done to preserve the switch for long life. I'm so glad we did because the room light dims briefly on power up. The brightness control and volume control which were integrated with the power switch were retained.
The cabinet was in good shape. There was one scratch on the side which was touched up without refinishing the entire cabinet. The safety glass was removed and the CRT and glass were cleaned. I share your concern and the CRT was never removed during the restoration.
I need to refinish the brass around the safety glass. I don't want to remove the glass if possible. Do you know of a good product I can use to remove the patina? I tried Brasso and it had no effect.
Old 01-22-2017, 04:54 PM
Originally Posted by Tomcomm View Post
Welcome to the 21CT55 club. I would like to see some full screen size, screen capture shots. I assume your included screen shots were thru the full RF/IF systems, right? It would be interesting if you could compare them with your computer monitor screen shots. Seems you have some color analysis contamination in the small detail. Looking forward to your further screen shots.
Tom,
In the link I provided, (within the image carasel) you can click on a tab to see the full resolution shots. I used a non-pro camera, an iPhone 6 Plus to capture the shots. The signal was OTA converted to analogue with a converter box. I'm still planning to adjust a bit more and create a video. I followed your treads on the 21CT55 and that CRT produces about the best color CRT screenshots I've seen from an old "roundie". The original CRT (21CT55) was replaced with a newer tube, right?
Old 01-22-2017, 04:55 PM
Thank you very much JR. :-)
Old 01-22-2017, 08:16 PM
That is odd...The same trim was used on the CTC-4, and I polished that trim on my CTC-4 with brasso. Did you forget to shake the bottle before using or forget to scrub?...I had to scrub mine vigorously with a discarded toothbrush to polish the tarnish off.
Old 01-22-2017, 09:23 PM
I tried with a soft cloth. I good try your meathod or maybe a Dremel tool with fine sandpaper, then seal with varnish?
Old 01-22-2017, 11:36 PM
ohohyodafarted's Avatar
Bob Galanter
The only way to get good results refinishing the brass is to remove the trim and work at it with successively finer grades of steel wool or scotch bright. The brass has a lacquer coating, that was sprayed on at the factory. Brasso will not do anything unless the brass is bare naked. Then Brasso can remove the tarnish. If you try to remove the lacquer coating using Brasso and a soft cloth, you will be expending many needless hours of labor
Removing the brass trim is easy. Behind the crt bezel you will find tensioning clips that hold the trim in place. Remove all the clips that hold the trim tabs in place. Then you can push the trim tabs forward, through the crt bezel and the trim frame can be easily removed.
If you try and clean the trim with Brasso with the trim in place, you will end up with Brasso in all the crevasses, and then there is still the problem of having to apply a new coat of clear lacquer to prevent future tarnish. No, varnish is not the correct product to use.
Click on the "Brass Refinishing" link under "MY Methods" section at my web site or click below
http://antiquetvguy.com/WebPages/MyM...finishing.html
ME http://AntiqueTvGuy.com
Old 01-23-2017, 01:42 AM
Bob,
I found out quickly about the Brasso getting in crevices as well as a soft cloth not working. Thank you for the suggestions.
Old 01-23-2017, 07:50 PM
Kirk's Avatar
Kirk Kirk is offline
Great Job! Went to your website and saw the pictures....I just started working on my 21CT55 again....you cant beat seeing Spock on a 21AX!
[email protected]
Old 01-24-2017, 01:11 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
etype2,
You might consider Bob's method of removing the old lacquer, but instead of using Brasso to polish the brass, use MAAS polish. I do brass instrument repair and restoration (I specialize in higher end pre-war Conns) and MAAS is the polish I always use before either silver plating or hitting the horn with new nitrocellulose lacquer.
