Old 02-08-2017, 06:11 PM
Kirk's Avatar
Kirk Kirk is offline
Exclamation 21CT55/CTC2B Parts Needed
I may be whistling in the wind but lets give it a try:
1. The LV Cage Cover (the roof over the selenium rectifiers)
2. The screen that is part of the metal cover on the bottom of the chassis. I have the cover frame, I just need the part with the holes in it.
PM me if you can help!
Thanks,
Kirk
[email protected]
Old 02-08-2017, 06:39 PM
miniman82's Avatar
First Light: 1952-2011
If you mean that perforated metal shield that goes under the chassis, you can find that stuff on eBay and cut it to size. Probably use the rest to make yourself a new cage as well, it's basically the same stuff.
Evolution...
