Old 04-28-2017, 10:45 PM
fifties's Avatar
fifties fifties is offline
Visiting Anachronism
Sony Betamax SL 2000 repair
I bought an SL 2000 off The Bay about two years ago, and it worked just fine.
Hadn't operated it since then, and when I went to use it the other day, although it would respond to the RCU command for power on and off, it wouldn't for play/stop/ff/rewind. They do work using the buttons on the unit.
Service manuals for it seem to be non-existent, except for one source who wanted about as much as I paid for the unit ($80).
Would anyone have knowledge on this type of problem? Obviously the IR path is clear, in that the power functions work, so I am guessing that the problem is downstream.
Old 08-28-2017, 08:41 PM
Doug Doug is offline
Maybe remote?.point the remote at your cell phone camera and push each button...I the infared led will flash on your camera.wesk batteries possible.
.if this remote is for tv also maybe switched for tv....
Old 08-28-2017, 09:37 PM
Lemme dig into my stash - I have a bunch of Sony Beta and U-Matic manuals, but it's late here, and my shop is in a detached garage, and a tropical storm is a 'comin, and well, you get the picture. If I have it, it's yours for postage.
Meanwhile, here's the only repair tips I have in my database...
USN RET 22YRS (Avionics/Cal)
Old 08-28-2017, 09:53 PM
fifties's Avatar
Thx for the responses, gentlemen! I apologize for forgetting that I had started this thread, so allow me to summarize the conclusion.
About a month ago, I had occasion to go to my favorite electronic junk store, All Electronics. While browsing around their combination of new, used, surplus, etc. stock, I noticed two plastic bins of stuff priced at a dollar, and whattayaknow, one of them was this remote, simply minus it's battery cover.
So being the sporting type that I am, gambled the whole buck, brought it home, put in batteries, and voila, I had remote control function again! The battery cover came off the malfunctioning one and on to this unit.
I am SO glad that it wasn't a failure of a component inside the SL2000 itself.
Old 08-28-2017, 11:06 PM
...takes off waders....
Old 08-29-2017, 01:30 AM
fifties's Avatar
Lost me on that, findm...
Old 08-29-2017, 09:22 AM
Sometimes the conductive sensor pads on the PCB in the remote get dirty and some buttons die...Whenever that happens I usually take apart the remote (if it is possible to do so without destroying it), clean the board and the side of the rubber button sheet that touches it, reassemble and all is well again. An old Panasonic I was using the snot out of for time shifting/archiving a decade ago used to need a remote clean every ~6 months.
BTW Brian. I've got a couple of Sony Umatics that I'd be interested in having the service manuals for VO-1600 and VO-5600. I'm not in a hurry so no need to drag out the waders.
Old 08-29-2017, 10:27 AM
fifties's Avatar
Good point on cleaning the the PCB push button contact areas, M, and I'm no stranger to having done that on other RCU's. Funny that I didn't think of it before, on this one. I guess the fact that the power button worked threw me off.
Also, I now get the "waders" remark lol. Gonna be 108° here again today, so mind's hardly on rain.
Old 08-29-2017, 11:54 AM
Twas raining cats and dogs here (tropical storm) and I had nothing to do, so...I was gonna go look in my shop for the manual and an Eico knob (for myself). We got several inches overnite - a good soakin'
Old 08-29-2017, 12:11 PM
fifties's Avatar
You can send that rain down thisaway, lol.
Old 08-29-2017, 01:18 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Might there be JVC U-Matic manuals in there as well? My CP-5200U needs a lot of attention but I won't be able to get back to it for a while yet. It had a melted roller which I cleaned up; fortunately quite a few 8mm projectors use the same roller so they're readily available.
Old 08-29-2017, 03:39 PM
No, just a few Sony U-matics. Sadly two are supplements only. I don't have the OPs manual, and I didn't take stock of what I have.
Old 08-29-2017, 06:02 PM
Do you happen to have any Sony VO-1600 or VO-5600 umatic documentation?
