Old 05-16-2017, 12:32 PM
TUD1's Avatar
TUD1 TUD1 is offline
Kig's TV Service
Zenith 25DC56 rolling
This TV, one of my favorites, has been out of commission for a few months after the vertical took a dump. It will not lock. You can get it close, but it still rolls really slowly. I tried a known good 9-83 module, and it did not help. After this TV broke, I put the 25CC50 tin can on top of it, and we watched that. But now we're watching the System 3 so the 25CC50 doesn't get a ton of hours.
Old 05-16-2017, 12:38 PM
Probably an issue with the sync sep circuit and or AGC setting. I forget what board it is on, but I should be able to get you more info off the schematic after work.
Old 05-16-2017, 12:57 PM
TUD1's Avatar
Kig's TV Service
About the AGC, I did have to adjust it when we first started using the set. It would have occasional "snow outs" were the picture would be super fuzzy for a few seconds and then stop. I adjusted the AGC and it solved the problem. It worked fine for months after that.
Old 05-16-2017, 01:32 PM
AGC adjustment typically has a low signal (blank raster/snowy pic) range, a mid range with a sweet spot, and an overload range where sync is lost and or grossly excessive contrast/negative pic occur.
Typically you turn AGC up till synch is lost and or pic contrast becomes overloaded, then back it down until sync stabilizes and contrast is in a reasonable range for it's control....It may be worth tweaking the AGC again to see if it is having an effect.
Old 05-18-2017, 09:25 AM
Never had one of these roll. There are a few small 'lytics on the
main chassis. One was in the AGC. IIRC it caused snow, look
that way first.
Old 08-11-2017, 03:31 PM
TUD1's Avatar
Kig's TV Service
Fired the old Zenith up again today and as expected, it still rolls. Tried adjusting the AGC, and it had no effect on the vertical at all. Probably a cap...
Old 08-11-2017, 04:09 PM
May want to tweak the blue static convergence while your in there...
Old 08-11-2017, 04:17 PM
TUD1's Avatar
Kig's TV Service
Doing any work on a TV this big is near impossible on account of the house is the size of a broom closet and there's no room to even walk. Even plugging it in was a PITA.
Old 08-11-2017, 04:24 PM
Vertical sycn is pulled from the 9-48 Module, off pin 3 of the 221-45 chip. Can you scope the sync there?
If I can find my Zenith Tech Topics binder (MIA right now..) there is an entire TT issue dealing with the 25DC56 and common problems. I remember scanning it, so I'll check my Canon scanner folder too...
USN RET 22YRS (Avionics/Cal)
Old 08-11-2017, 06:27 PM
The AGC on these is RF AGC. Put on strong signal & adjust
till the pix goes snow then turn back until the snow JUST clears
up. Its touchy & will cause the jitters if set to high.
BTW for you & others. Zenith made a training manual with
paper & cassettes that covers the 4 tube hybrid, flat chassis &
the CC2 upright chassis. I recommend it, I see them on e-bay
now & then. Its amazing how close they are to each other & uses
many of the same parts & design. Great way to see slow evolution.
Old 08-11-2017, 09:41 PM
I've got the cassettes still - green and orange? body to them - covers the flat chassis, 19EC45/FC/GC IIRC, and one other chassis. I no longer have the training manual - my copy got messed up thanks to a Coke can prank gone horribly wrong.
Those Duramodule sets were the easiest to service - and no need to stock a million modules like the later System III sets.
